More wiring question
Old Nov 23, 2005 | 07:40 AM
mliers's Avatar
Car: 1992 Camaro
Transmission: Auto :(
Axle/Gears: 94 Formula rear end with 3.42s
I've got a 93 painless harness and there is the Ignition B+ fuse wire...anyone know exactly where that would go? Manual said it needs to have power when the car is in the start and run position. Klortho said it goes into one of the plugs under the passenger side dash, but just wondering if anyone knew exactly which wire same with the wire to power the injectors....ive got a 92 btw
Old Nov 24, 2005 | 01:18 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
ignition while cranking means that you need to probe your ingition power wires with the ignition on and then turn the key to the start position. The wire that stays hot is the winner. Not all ignition wires stay hot when the key is turned to on. This is why the radio doesn't stay on while cranking.
Old Nov 25, 2005 | 10:27 AM
mliers's Avatar
Car: 1992 Camaro
Does anyone have any pics of that connector under the dash that has to be spliced into? Any pics of wiring would be great, thanks.
Old Nov 27, 2005 | 01:10 PM
Firebat's Avatar
the connector is blue for the ignition
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
