best LT1 year
Old Dec 25, 2005 | 01:43 PM
zstalker's Avatar
best LT1 year
is there any difference in LT1's from year to year? I'm working under the assumtion that I'd be rebuilding the motor, possibly new custom pistons, so I'm really just asking about the block, crank and heads. While we're at it, would it also be safe to assume that LS1's are the same as well (same as above...ignore cam, etc)?
~Erik~
Old Dec 25, 2005 | 08:02 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
'95 is probably the best year, vented non-splined opti, biggest cam of the LT1's and also the best thing, OBDI instead of OBDII
Old Dec 25, 2005 | 10:36 PM
Firebat's Avatar
i second that. 95
the best block would be from a vette, they have 4-bolt mains, f-body has 2 bolt mains
Vettes and f-bodies have aluminum heads
Old Dec 29, 2005 | 10:49 AM
Vader's Avatar
But the stock iron heads flow better than the stock aluminum heads.
Old Dec 29, 2005 | 11:53 AM
TexasLT1's Avatar
Car: '92 RS
only unported, and you're only talking about 5 cfm. not worth it.
Old Dec 29, 2005 | 08:32 PM
zstalker's Avatar
so if I were transferring the whole system (engine, tranny, rear, wiring, computer, interior including gauges) would it be as big of a concern to run an (1996-up) OBDII? with the OBDII system I figure I'd have a better bet of communicating with the system...just my thought.
And as for the heads, you're saying that the stock iron heads flow better, but not much better...so I might as well get aluminum heads for the weight savings and carefully port them...right?
sorry I'm normally an Old Mopar guy, so my other favorites (thirdgen camaros) are somewhat newer to me.
~Erik~
Old Dec 29, 2005 | 09:05 PM
Klortho's Avatar
Car: 1987 GTA
OBDI for tuning, alot of guys running the OBDII LT1's are converting to the OBDI system
Old Feb 2, 2007 | 10:16 PM
zmack28's Avatar
verting OBD
I am about to start installing a 96 crate LT1 into an 89 TBI. I have a 97 OBDII from a 97 Z28, NO wiring harness yet. what recommendations do you recommend based on reading that OBDI's are better. Should I get OBDI?
Old Feb 2, 2007 | 11:54 PM
Firebat's Avatar
OBDI is easier to tune. OBDI is easier(cheaper) to monitor. OBDI uses only 2 oxygen sensors while OBDII uses 4, but OBDII can be programmed to work off of 2.
The 96-97 wire harness is backward compatible to the 95 wiring harness, meaning that a 95(NOT 94) PCM(computer) will work on it.
Unless you plan on tuning or monitoring the sensors by yourself then probably wouldn't need a 95 PCM. However, an OBDI LT1 with a tune will yield about 10 more HP than a tuned OBDII LT1, while using 91+ octane.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
zayne0
Aug 24, 2015 07:22 PM
