Will Hedman 68460s work on an LT1?
Old 01-05-2006, 02:08 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
I searched and couldn't find anything specific about the LT1. Will the Hedman 68460 long tubes work OK with the D port LT1? Will the ports be completely covered so they don't leak? I know I'll have to weld in the O2 fittings, but I don't need the AIR fittings. I've got the headers already, and at this point, I just want to get the LT1 in and running. I'll worry about making real power later when i'm not so broke. Thanks for the info.
Old 01-05-2006, 03:08 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I would get the d-port shorties and y-pipe that hedman makes, that's what I'm using and they work great. That way you don't really have to worry about ground clearance or making a custom tranny crossmember so they will clear.
Old 01-05-2006, 07:44 PM
mliers's Avatar
Car: 1992 Camaro
Transmission: Auto :(
Axle/Gears: 94 Formula rear end with 3.42s
I got some 92 hooker headers and the y-pipe that went with that, and it fits great as well. $150 at summit i do believe and then the ypipe was another $150 or $200.
Old 01-05-2006, 07:52 PM
Coach Hawk's Avatar
Thanks for the info. I'll trake that into concideration. I plan on running true dual though so I won't need the y-pipe. It also would be convenient for me to have collectors that are already pointing back instead of down.
Frozer!!!
01-19-2024 04:55 PM
midge54
12-27-2019 04:14 PM
midge54
01-29-2017 07:00 PM
sreZ28
08-14-2015 07:48 PM
1992 Trans Am
08-08-2015 08:16 PM
Quick Reply: Will Hedman 68460s work on an LT1?
