lt1 no idle
Old Jan 23, 2006 | 01:07 AM
92firebirdLT1's Avatar
lt1 no idle
my swap is almost done just a small question for those of you who've finished the car cranks over starts and if i hit the gas will stay running as long as the pedal is depressed 1/4 throttle or more but about 2-3 seconds after i let off the pedal the car will die its not the vats because i deleted it off the pcm any help would be great ive gotta get it done so its outta my stepdads building so he can store his solstice till he's back from mexico
thanks
Steven
Old Jan 23, 2006 | 04:04 AM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
Did you check your TPS voltage? If that is correct, you may have a bad sensor such as MAF or MAP. Could also be a vacuum leak of some sort or a bad IAC valve.
Old Jan 23, 2006 | 07:05 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
You know, mine was doing the same exact thing, turned out the original fuel pump relay wasn't giving enough voltage to the fuel pump...I swapped it out to a standard 4 pole 40amp relay and everything is working like a charm now. Also when I hit the gas, it would sound like it was running out of gas as well.
Old Jan 23, 2006 | 08:20 PM
LT1powered89's Avatar
Car: 1989 Chevrolet Camaro
Axle/Gears: 2000 rear, 3.73, auburn locker
Not saying your wrong but when I did my swap, the IAC went bad and the car would start and idle at 1500rpm and then slowly work its way up to idling at 2500rpm. It was a really weird problem and took an hour or two to figure it out.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
New2Chevy
Sep 28, 2015 12:35 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
L0tuS
Sep 4, 2015 11:16 PM
