Hot Cam Kit
Old Jan 26, 2006 | 11:27 AM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
Hot Cam Kit
I have an LT1 out of an Impala SS and I want to upgrade the cam.
I was wondering if the Hot cam kit would be suitable for this upgrade eventhough I had iron heads?
Thanks,
Jay
Old Jan 26, 2006 | 02:53 PM
TexasLT1's Avatar
Car: '92 RS
Hotcam is good, but there are other ones out there that will give you better power and the same driveability. Do you have to pass emissions?
Old Jan 26, 2006 | 03:58 PM
Car: 1991 Z28 Vert
Engine: LT1 350
Emissions
In michigan I don't have to pass emissions. Could you offer some other suggestions around the same price ranges.
Thanks,
Jay
Old Jan 26, 2006 | 09:09 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
with a 2400 stall, I would look at maybe either the CC305 or CC306, the 305 is a little more forgiving for the stall, but both would need at least a 3.42 to take advantage of them, a 3.73 to give it a good kick. The hotcam, as well as these cams would need upgraded valve springs on the heads to take the lift.
Old Jan 26, 2006 | 10:06 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
And since you need springs anyway, beehive springs and 1.6 RR's would be a great add on as well
Old Jan 27, 2006 | 12:22 AM
Car: 1991 Z28 Vert
Engine: LT1 350
Thanks for all the help guys.
Are all these cams around the same price range?
Which is actually the best bang for the buck?
Jay
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Mickeyruder
Sep 2, 2015 02:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TreDeClaw
Aug 14, 2015 06:58 PM
