Photos from the weekend's work
Old Feb 13, 2006 | 01:54 PM
z28evans's Avatar
Car: 89 iroc
Finished up modding the stock ls1 harness, ran the wires. Mounted the radiator hoses, accessories, heater hoses (with a bypass), and lots of other misc. When i did the brake lines i moved them to the other side of the steering shaft to clean up the enginebay. I ran the wires into the passenger compartment.
I learned that there is a difference in the exhaust flange for the 98 vs 01 style exhaust manifolds. The 98's have the flange closer to the firewall, the newer style has it further forward.
On the heater hoses i wanted to maintain a heater core bypass to keep the hot air out. Ls1's need to have the return T'd back to the motor. Do not send the hot water back to the radiator - you will have cooling issues.
Very happy with how it looks, just need to finish up the inside next.
More photos here: http://www.bubbadrift.com/album/thumbnails.php?album=26
James
Old Feb 13, 2006 | 06:47 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Something I've noticed on mine and a lot of other swaps and I don't know the answer. Why is the motor shifted to passengers side?? It's really been ticking my off trying to get my ram-air filter setup right.
Kevin D.
Old Feb 15, 2006 | 02:24 AM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
So your using the stock airbox? Don't you think thats going to be a major restriction?
Old Feb 15, 2006 | 09:01 AM
z28evans's Avatar
Car: 89 iroc
Not sure, used spohn motor mounts.
I do believe that it is a major restriction, but it will do for the time being. Once everything is finished and running i can redo this later.
Thanks,
James
Old Feb 15, 2006 | 11:30 AM
91Z28-350's Avatar
You have a PM.
Frozer!!!
Jan 19, 2024 04:55 PM
Linson
Aug 21, 2015 02:12 PM
justin57
Aug 20, 2015 07:05 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
BBSDesigns
Aug 11, 2015 07:39 PM
