evap question
Old Feb 16, 2006 | 01:53 PM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
evap question
I searched but didn't find exactly what i was looking for. I will be doing a ls1 swap eventually, EVENTUALLY, so i would like to know about the evap syatem. I understand how to run the lines to the motor from the 4th gen tank. My question is, where do you install the return line in the engine bay? I don't have an ls1 in front of me but is there a place on the engine the return line hooks to?
Thanks and sorry if this is redundant,
Brandon
Old Feb 16, 2006 | 04:12 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Re: evap question
Brandon
I guess you didnt search hard enough bro LOL!!! You should have a fuel T to tie together the Supply and Return together. The only lines that run to the front of the car is supply and EVAP, check this pic that i made.
Old Feb 16, 2006 | 08:49 PM
Camaro0605's Avatar
Car: 1991 RS
Do we need to hook the silonoid at the charcoal canister of the 4th gen tank up to use the 4th gen emissions, or will it work as long as the silonoid by the fuel rails are attached.
Old Feb 17, 2006 | 10:36 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Im not to sure about that, but i would hook it up just in case, My thoughts on stuff like that is, "It must do something" LOL.
Old Feb 17, 2006 | 10:53 AM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
i know how to run lines off the tank. I wanted to know what the return line hooks up to in the engine bay.
Old Feb 17, 2006 | 10:58 AM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Return line hooks up to the other line coming off the rail (EVAP). You can buy braided line an adapters for both fuel and EVAP, but honestly hose and clamps is fine for return/EVAP.
Kevin D.
Old Feb 17, 2006 | 11:10 AM
b's90cam's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
oh so off the fuel rail is an evap line? That makes sense now.
I hope i can find an engine so i can start this swap. I gonna have to buy a s10 for a daily driver first because my car will be down for a few weeks
Old Feb 18, 2006 | 08:32 PM
87Ls1Camaro's Avatar
Car: 87Z28
Engine: 98 Ls1
Transmission: 4l60
Axle/Gears: 307
Evap
I still got a 3rd gen tank in my ls1 swap, thing is the 4th gen had the pressure sensor in the tank to purge vapor into the canister/intake , unless you got the sensor and the computer programmed to do this you dont need a evap canister. I looked around for info on how to do the setup also, I guess it comes down to what all you got and customizing it. Also If you got local emissions tests you need it. If you have the 4th gen tank in I would just take the vapor line from the sending unit and take it to the canister then canister to the vapor line on your frame-to engine and then run that into the intake purge. have you canister in the rear like the 4th gens. I hope this helps
Old Feb 18, 2006 | 08:39 PM
Car: 87Z28
Engine: 98 Ls1
Transmission: 4l60
Axle/Gears: 307
return lines
Also I forgot with the return line theres 2 ways you can do this , I went with a modified fuel rail and put a return on it there and ran that back to the tank conecting it to my original hard line. I saw the other way on ls1tech.com with a corvette part not sure exactly atm the setup so not gona try to get into it sorry,
1992 Trans Am
May 10, 2023 07:19 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
dyeager535
Aug 28, 2015 08:10 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
