help required within=\
Old Mar 2, 2006 | 11:42 AM
xomega's Avatar
Car: 1990 chevy camaro rs
Engine: lt1
Transmission: 4l60e
Axle/Gears: 273:(
run down on the car. 90 camaro rs. 305 tbi. project is instaling a lt1/4l60e. having a bit of the wiring issues here. looking at shbox i see cavity h in plug c230 <95 lt1> (automatic) tcc switched power feed. and i also see. cavity j (automatic) park/neutral feed from transmission position switch. where do these two wires go? thanks
below is the 90 camaro bulkhead bulkhead pinout.
http://img208.imageshack.us/img208/8...ulkhead2eg.jpg
http://img208.imageshack.us/img208/1...dpinout8bq.jpg
Old Mar 2, 2006 | 02:23 PM
1991 RS/SS's Avatar
Car: 1991 Camaro RS
Engine: 383 LT1
Axle/Gears: 4.10
I am not 100% positive on these, but here goes...
The park/neutral wire from the ecm should be org/blk. Cut the org/blk coming out of your shifter and splice the lt1 org/blk onto the half of the cut wire coming out of your shifter so the org/blk now goes from the ecm into the shifter. The p/n should be a negative trigger, IIRC.
By TCC switched power feed, I am assuming you mean the lt blu/blk wire coming from the ecm. If so, this wire will go into the car to the brake switch. Cut the purple wire coming out of the brake switch and splice the lt blu/blk into the half of the purple wire coming out of the brake switch, so the lt blu/blk goes into the brake switch. The brake switch signal is a positive trigger, IIRC.
Old Mar 14, 2006 | 08:40 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Anybody else notice the scan in fax. It was from jerrys imports ! WTF!
Old Oct 16, 2008 | 12:12 PM
Daves03's Avatar
Car: 1991 Chevrolet Camaro RS Red
Engine: 305 V8 TBI
Transmission: TH-700R4
Re: help required within=\
thanks so much xomega for your bulkhead connector pinout im diagnosing my speedometer problems with it, i really appreciate your pinout.
Old Oct 16, 2008 | 11:47 PM
Slouch's Avatar
it could always be a manual from england?...
Old Oct 17, 2008 | 11:01 AM
krisb410's Avatar
Haha, not from England, I work at Jerry's Mitsubishi/Chevrolet. I copied the diagrams out of the factory service manual and faxed them to xomega. I just thought it was funny because the header on the fax said Jerry's Imports, and not Jerry's Chevrolet, it was kinda an inside thing that you had to be there. This thread is 2 years old now, awakened from the dead.
Later dudes
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
ZZ3Astro
Aug 13, 2019 12:57 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
