What is it and can i remove it?? (LS1 Swap)
Old May 6, 2006 | 11:28 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Not sure what this is but i think it has something to do with fuel tank pressure? Can it be removed without causing any problems? I'm talking about the sensor on the front left corner of the intake, has a line going into the intake just before the throttle body. Thanks, Jt
Old May 7, 2006 | 02:02 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
its the evap.. you can vent the stock tank (ur old evap was the charcol canister thing) and remove that sensor and the codes from the ecm.. as long as u dont need emissions stuff
i dont know if that sensor needs the other sensors found on the ls1 gas tank to function or if you can hook the 3rd gen tank vent line up to it and hope it works would have to do a search
Old May 7, 2006 | 03:13 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
well, thats cool. I removed my charcoal canister and lines from the car so guess i dont need it. All the emissoin stuff was removed from the computer so i am guessing it wont be an issue, just need to plug the intake with something?
Frozer!!!
Jan 19, 2024 04:55 PM
1984HO
Mar 19, 2021 11:59 AM
NBrehm
Aug 25, 2015 11:49 PM
reiderz iroc
Aug 13, 2015 04:57 PM
3rdgenparts
Aug 8, 2015 07:09 PM
