VATS Bypass
Old May 26, 2006 | 08:27 AM
dtsfanatic's Avatar
Car: 1987 Trans Am
VATS Bypass
Quick question guys. I know for the fbody cars that you can get a VATS bypass module or defeat it in other ways, however I am using the PCM and wiring harness from a corvette. Does the same work on the vette setup, or do i have to have it turned off in the PCM?
Old May 26, 2006 | 09:11 PM
Firebat's Avatar
its best to have it turned off with a pcm tune. You'll probably need a tune anyway if you throw away egr, and that emissions crap. Should be the same as f-body.
Old May 27, 2006 | 06:18 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
Yes, it should work on the Vette PCM, but like Firebat said, if your getting a tune anyway(which you should), you can just have it turned off then.
Old May 27, 2006 | 08:03 PM
dtsfanatic's Avatar
Car: 1987 Trans Am
Thanks for the replys guys. I think tomorrow I'm going to take the wiring harness off the engine and send it and the PCM to 350lt1. I've heard good things about this company. I looked at the wiring today using the LT1 wiring for dummies tread and found that the wiring colors and pinouts do not match the fbody harness. So I think the best thing to do is send it out and get a tune at the same time. I hope they do a good job, I've just about got everything else hooked up and ready to go. Can't wait to hear it run.
junior419
Apr 7, 2025 11:35 AM
$750 L98
Feb 1, 2025 02:25 PM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
Racerx974
Sep 19, 2015 10:16 AM
