LT1 timing chain
Old Jun 5, 2006 | 05:39 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
LT1 timing chain
Hey I have a freind who is swapping in a cc306 cam. And wanted to know if it was nessary to buy a heavy duty timing chain or would the $45 do the job? We found one in jegs but it is $245 *ouch* Thanks
Old Jun 5, 2006 | 06:12 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
I have the LT-4 Cam in my L-98 with the stock timing chain.It is new though,and only had a few easy miles on it but i dont see why it wouldnt be fine.Sorry i misread your post i thought you were putting in the LT-1 cam.Im not sure about that cams specifics but my guess is you might want to use the heavy duty onr
Old Jun 5, 2006 | 07:06 PM
Coach Hawk's Avatar
Car: 91' Pontiac Firebird
Use the heavy duty one, and remember, it's LT1/4 specific. You will probably be ok with the standard, but do you really want to risk it?
Old Jun 5, 2006 | 08:00 PM
Car: 1992 camaro
Axle/Gears: 3:73
no i dont but is jegs the cheapest place? Summit&SDPC are higher dont know about local dealer yet
Old Jun 5, 2006 | 09:01 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
I don't see why you need to run the HD LT4 timing set. I am running the same cam and I beat the crap out of my motor. All I did was replace the timing chain itself with an Advance Auto replacement and put the motor back together. I wasn't about to drop the cash for the upgraded setup when there was nothing wrong with the existing one.
Old Jun 6, 2006 | 07:13 PM
Car: 1992 camaro
Axle/Gears: 3:73
Ok i have another ? 1981LT1 the guy told him at comp cams to check for valve clerance. He is not having the heads shaved so we dont think this will be a problem did you have any problems with valve clearance?
Old Jun 6, 2006 | 08:42 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
I saw a heavy duty roller timing chain set with double chains by eddelbrock for under $100.00.iIt was at the jim pace G.M. performance parts.
Old Jun 6, 2006 | 08:46 PM
1981LT1's Avatar
Engine: LT1; LT1
Clearance problems, no. I had to machine the heads for bigger springs and I upgraded to the Comp Magnum roller tip rockers (1.6 ratio). While the heads were at the machine shop, they decked the heads a few thousandths and put a 5-angle valve job on them. Everything works flawlessly and there is no clearance issues.
Old Jun 6, 2006 | 09:04 PM
Coach Hawk's Avatar
If your using B-body iron LT1 heads, you may have valve guide/spring retainer clearance issues, which requires the guides be machined down a bit. I don't believe it's a problem with the aluminums, but double check to be sure.
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
MY87LT
Aug 17, 2015 08:43 AM
Thirim
Aug 9, 2015 06:19 PM
