LS1 02 sensor question
Old Jun 16, 2006 | 09:58 AM
tuske427's Avatar
Car: 1984 Trans Am
Engine: 2002 LS1
Transmission: 6 speed
Axle/Gears: 3:73
HI:
I will be picking up my '84 T/A from the exhaust shop tomorrow and they have it about all set but they did not install the 02 sensors because they did not know which ones went where. They said that on many cars there are differences between the front and rear 02 sensors.
Is this the case with the ls1 engine? are the 02 sensors specific for the front and rear? or does it not matter? If they are, how do I tell which ones go in front?
any help would be appreciated.
Thanks,
-BV
Old Jun 16, 2006 | 01:50 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
i remember the dealer asking me what O2 sensor i was replacing on my 97 subruban.... I was like huh?? I thought they were all the same. But the rears and fronts are different. Should be the same for the camaro??? Im not sure cause i think the LS1 O2 sensor connector are the same....WTF
Old Jun 16, 2006 | 05:16 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
If you didn't modify the wiring, the ones with the longer leads go in the rear..
Kevin D.
Old Jun 16, 2006 | 05:33 PM
ThirdGenLS1's Avatar
Car: 1991 Camaro
the rears have a longer wire feed and read a tad diffrent since they are farther back. Are you running LT's or just exhuast manifolds, if you have LT's just stick rears in teh front since the headers bring the 02 farther back.
Justin
Old Jun 16, 2006 | 07:18 PM
tuske427's Avatar
Car: 1984 Trans Am
Engine: 2002 LS1
Axle/Gears: 3:73
cool, thank you!
for now the exhaust is stock (02 manifolds, 02 engine) and the wiring was sent to speartech, but he probably didn't alter the 02 wiring length.
thank you for your help!!
Old Jun 16, 2006 | 07:21 PM
Car: 1991 Camaro
then you just need 2 front o2's and 2 rear o2's. That or you can just delete the rear o2's with the comp and not even run them. They are just there to make sure the cats are working.
Old Jun 18, 2006 | 02:39 PM
trans_am_31's Avatar
Car: 85 Trans Am,79 Trans Am,02 Trans Am
Engine: 5.7 V-8 346 LS1
Transmission: Automatic
I went with two O2's in front and then deleted the last two with HP tuners or you can get the O sims.
Old Jun 19, 2006 | 03:38 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
front O2s are for fueling.
the ONLY reason the rear O2s exist is to check if the catalytic converter is functioning properly.
if this is a non-emissions swap, delete the rear O2s in the PCM, or run O2 sims.
as far as function goes... it doesnt matter what O2s you use, front, rear, or corvette.... they all have the same switch point.
most guys running longtubes run bosch 3111 O2s.... they're intended for the corvette, and have a more powerful heating element.. perfect for the cooler exhaust temps of longtubes.
Old Jun 19, 2006 | 03:57 PM
Car: 1991 Camaro
Exactly
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
