Stock K-member vs. Hawk's Tubular for LS1 Swap
Old Jul 30, 2006 | 01:33 PM
1irocz2nv's Avatar
Hey everyone. I had some questions about the stock K-Member vs. the Hawk's tubular member. I know there are some weight savings and more room for headers with the hawks version. Are there any other advantages with the hawks version?
I'm still undecided about which k member I will use for my LS1/t56 swap next year.
I would like to retain AC for my swap and I know if you use the 4th gen AC that you need to notch the factory K member. Do you still have to notch the stock K member if you use the 3rd gen AC and accessories with the relocation kit? I'd imagine with the Hawks K member, the AC wouldn't get in the way of anything because of the increased room?
Last question. If I do use use the stock k-member, which aftermarket motor mounts seem to work best with the swap (fitment and so on) as I have heard some people complain about fitment issues.
Thanks guys, your opinions would be greatly appreciated and sorry the long post.
Old Jul 30, 2006 | 02:03 PM
atvance's Avatar
Hawk's is not DOT approved. Not sure about street use, but drag/race probably good.
Old Jul 30, 2006 | 02:05 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
Check out the LSX Sticky at the top of this forum.
More room and using the LS1 A/C compressor w/o notching is the advantage of going with a tubular k-member. I wouldn't do it for the weight savings, even though there might be some.
I'd go with the Spohn mounts.
Old Jul 30, 2006 | 02:15 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I think the Hawks/Spohn K-member is a myth .
Old Jul 30, 2006 | 04:30 PM
badjuju342's Avatar
Car: '89 rs convertible
Engine: ls1
Axle/Gears: 3.73 posi
Not at all , I have one .Do a search on a thread titled "pics of the Hawk's LS1 K-member ". Plenty o' pics!
Old Jul 30, 2006 | 08:44 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
I've got one too. Personally, I'm not so sure it was worth it.
Old Jul 30, 2006 | 09:48 PM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
The Hawk's/Spohn one is a myth. The old Hawk's one a local guy was building does exist. As Steven an I found out, it takes a little modifying to work right.
Kevin D.
Old Jul 31, 2006 | 07:51 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Not really a cost effective mod IMO. Too pricey for so little gains. Spend the dough on other aspects of your build and notch the stock c member. If you cant notch the c member yourself then I would reconsider tackling this swap unless you have DEEP pockets
Old Jul 31, 2006 | 10:02 AM
StevenK's Avatar
Car: 91 Z28
Eventually I will have tubular everything, its just one step in that direction.
Another nice thing about the tubular unit is you can easily go to a rack and pinion set up.
Old Aug 1, 2006 | 09:18 PM
kairles's Avatar
Engine: 383/LGX
I was talking about the new one by spohn. the reason I said that is because Im one of the people that has paid for it and is still waiting..........for now
Old Aug 2, 2006 | 12:27 PM
badjuju342's Avatar
Engine: ls1
What's up with the old one? The one I have is still in the box and I haven't used it yet. I have seen something about the steering hitting lower accessories on the engine but I bought a kit from S&P and relocated everything to the top of the motor. A little more info on this?
Old Aug 2, 2006 | 11:43 PM
StevenK's Avatar
Car: 91 Z28
Mine (old version) had a problem with the steering. The drag link would hit the k-member when turning the wheel to the right. I had to flip over the drag link to get enough clearence on the tie-rods
Old Aug 6, 2006 | 10:35 AM
shr00m's Avatar
Plus it most likely will not work with stock A-arms without a BFH.
Kevin D.
Old Aug 6, 2006 | 10:38 AM
badjuju342's Avatar
Engine: ls1
I'm using the Spohn tubular A-arms.
Old Aug 12, 2006 | 09:09 PM
89FormulaLS2's Avatar
Car: 89 Firebird Formula
Engine: Custom Forged 402ci LS2 w/STS Turbo
Transmission: T56 6-speed
Axle/Gears: Moser 9" with 4.11
I've got Hawks tubular k-member and the Spohn tubular A-arms, installed by Hawkins himself.
Great LOOKING mod, in my opinon.
customblackbird
Aug 15, 2021 10:16 PM
1984HO
Mar 19, 2021 11:59 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
