LT1 TRACTION
Old Aug 6, 2006 | 06:27 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
LT1 TRACTION
I finnaly got all the bugs worked out of the lt1 third gen swap. Now for you guys that have already done this swap (lt1 auto into a third gen), at what percentage throttle do your tires breaks loose?
Mine breaks loose under half throttle. I am running 275/40/17 bfg g force tires, I know that there is not much side wall but I really do not want to put slicks or drag radials on it. I was thinking that I would put dag radials on the stock 15" rims for the track.
I have adjustable kyb agx shocks and struts how should I set them up for traction?
I also relocated the control arms and have all hotchkis and edelbrock suspention components.
How does everyone get traction with their lt1 swap??????????
Old Aug 6, 2006 | 06:28 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
I don't. Mine will break them loose in first and second when hammering on it. Now if I go from about 20mph it will break them loose a bit in first. But from a stop, forget it 2000 rpm and it's sideways.
Old Aug 7, 2006 | 09:43 AM
mateo's Avatar
Car: 90' Trans Am
Engine: 94' LT1
Transmission: Built 700R4
ditto...w/ shift kit and all that jazz in my tranny just regular 15mph quarter throttle chirps 2nd....I gotta be careful turning at lights if the cars gonna shift into 2nd or I better hold on tight.
Old Aug 7, 2006 | 01:59 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
you have to learn how to feather the throttle.. with street tires I could break 1st, 2nd and chirp third.. anything more than 25% throttle and an aggressive clutch would spin them on a heads and cam car. Best I can say is all the rear suspension mods in the book made her not step sideways too much, just make a lot of noise and smoke with no movement
Old Aug 7, 2006 | 02:08 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
well, i DRIVE my car, instead of holding the pedal a percentage... soo.
if i try to spin them, they spin.
if i just want to go, they dont spin much, if at all.
theres not going to be a TPS value where they spin at...
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
dbrochard
Sep 7, 2015 09:41 AM
L0tuS
Sep 4, 2015 11:16 PM
