Starting LS1 Swap..
Old Sep 6, 2006 | 11:36 PM
BushyTea's Avatar
Car: 1990 Camaro
Engine: 3.1 V6
Starting LS1 Swap..
Hey guys,
I have done tons of reading and read all of the FAQs but have a few questions.
Car is a 1990 Camaro and I am going from the V6 to the LS1.
I know I will have to swap such things as springs to hold the v8 but I had some questions over some of the swap parts.
Wiring Harness/ECU:
So I need the LS1 wiring harness and LS1 ECU to take the place of my camaros harness and ecu? then send them off to get the harness rewired and the ECU programmed?
Fuel Lines:
Do I absolutely need the fuel pressure regulator or if I buy the 97 Vette fuel rail that will take care of the regulator?
I believe thats it for now. Just had those few questions.
Thanks in advance,
Mike
Old Sep 7, 2006 | 01:27 AM
AdamsIroc-Z's Avatar
Car: 1987 Camaro Iroc-Z
Engine: Built 355 LT1 T-Trim
Transmission: T56 6 spd
Axle/Gears: 9 bolt 3.73 gears
you will need a combination of your stock 3rd gen harness and the LS1 harness and ECU. You will no longer need your third gen ECU. Basically the plugs that go under the passenger side dash and the ones that go connect to the firewall near the brake booster are the only parts you need off the third gen harness. The 97 vette fuel rails will look after your reg issue but it might be a good idea to run an aftermarket adjustable unit if you plan to upgrade the engine and fuel system in the future.
Old Dec 19, 2006 | 03:04 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Is it possible to modify the two harnesses to make the engine work without having to send it off somewhere? I'd rather not have to pay to have something done that I could do myself.
What's the advantage to the 97 Vette fuel rails? And where is a good place to get them?
Old Dec 19, 2006 | 03:15 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
yes, you can wire up the two together.
everything you need to know is availible thru a search on here and LS1tech.com
i posted up the ENTIRE wiring for 91 camaros... and the entire pinout of Fbody LS1 harnesses is availible online.
Old Dec 19, 2006 | 03:57 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Kool. Thanks for the info. Now...if I can find these articles. Could you give me a link to your post, please?
Old Dec 20, 2006 | 08:43 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
im not motiveated enough this morning to find the post... lol
but heres a current, direct link to all the wiring:
http://fastgm.com/wiring/
save the first few PDFs (#1 thru 6) to your computer. thats EVERY wire for your 91 camaro.
the rest of the LS1 stuff is easily found on LS1tech.
Old Dec 20, 2006 | 10:32 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Wow...that's alot of wires. Going to be interesting to pick through. Thanks. That should make things easier.
Old Dec 21, 2006 | 05:48 PM
slick00m's Avatar
Car: 1989 Camaro IROC
Engine: 6.0 LQ9
Fuel system
Here is a good thread on LS1tech about the fuel system.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
reiderz iroc
Aug 13, 2015 04:57 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
