rhetorical mount questions...
Old Oct 13, 2006 | 04:27 PM
bygblok's Avatar
has there actually been anyone who has figured out what mount package works best on the third gen car/ls swap yet? I'm looking at the trans dapt kit right now but not sure since I've heard so little about them. Seems like every company has a different issue with fit and NONE work well without some real persuasion....even the more pricey ones. I'm shying away from the tubular crossmember for budgetary reasons if nothing else. I'm also doing a TH350 with a divorced torque arm so I'll have to find or fab a tranny member as well unless there a ready-made one for that too. I guess I'm just used to the old school way of just dropping a motor in, wire it, fire it and go. This LS stuff is a huge change but I think it will be well worth it. Thanks for any info and even pics if available, Bill
Old Nov 5, 2006 | 08:34 PM
RacerDad916's Avatar
Car: 89 Z28
Engine: 355 full roller, Brodix 10X heads
Transmission: Close ratio Muncie
Axle/Gears: 3.42/7.5
550-40095 Torque Arm
For 1982-2002 Camaro/Firebird
$259.99
550-40097 1982-02 Camaro/Firebird Torque Arm with Adjustable Pinion Angle
$304.99
Here is what Jeg's has for torque arms that dont bolt to the trans. Has anyone use them? I just bought my first third gen Camaro. Is it as good as it looks?
Old Nov 5, 2006 | 08:40 PM
Car: 89 Z28
I thought you could use the stock x-member? I didn't think the trans mount location was different from 700 to a 350. Let me know if I'm wrong...
Old Nov 5, 2006 | 10:27 PM
bygblok's Avatar
I'll have to make some measurements on the trans mounts to see about the stock crossmember. My primary question has to do with motor mounts. I will need to solid mount my motor since it's primary duty will be spent 1/8 mile at a time. I was wondering about using the block plate adapters and a normal solid mount(moroso etc) to mount it to the frame. I just want to get the damned thing set in place so I can decide where I want everything to fit etc. It's almost frustrating enough to stay with a conventional sbc. It's bound to get better.......
92projectcamaro
Sep 12, 2015 12:33 AM
ynk1121
Sep 12, 2015 12:27 AM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
