LSx A/C pictures
Old Nov 8, 2006 | 03:44 AM
little Potato's Avatar
Car: 71 chevelle, 73 camaro, 94 probe
Engine: 408 bbc, 360 sbc, 2.5l v-6
Transmission: 4spd, 3spd, 5spd
Axle/Gears: 10 bolt 4:10, 10 bolt 3:42, stock
LSx A/C pictures
Does anybody have pictures of the f-body motorsports (or similar) LSx A/C bracket from the top, rear, and side of the compressor? I want to see if there might be enough clearance to move it closer to the engine so I can use Vette P/S and alt. brackets.
Old Nov 8, 2006 | 05:24 PM
Red92RS's Avatar
Car: 1992 Camaro RS
mine should be done pretty soon, i will try to get someone to upload a picture
Old Nov 8, 2006 | 05:45 PM
That would be great. Thanks
Old Nov 8, 2006 | 05:56 PM
dingle's Avatar
Car: '83 Camaro
Here you go. This is the A/C bracket from Fbody motorsports. I had to add a shim(fairly skinny washer) to the lower left mount to the engine. In a few of the pics you can see what happend when I didn't have the shim in there, the belt would ride up on the A/C pulley.
Old Nov 8, 2006 | 06:58 PM
Thanks for the pictures. It looks like I can use that bracket with the Vette stuff as long as I use a Vette tensioner and no/less spacers. Can you see anything that the compressor might/would hit if you moved it back?
Old Nov 8, 2006 | 07:12 PM
dingle's Avatar
Car: '83 Camaro
How much further back are we talking about?
Old Nov 8, 2006 | 09:11 PM
Probably without the spacers. If it can then I know what range I have to work in. I'm getting conflicting info on how the pulley offset between the two differs.
Old Nov 8, 2006 | 10:34 PM
dingle's Avatar
Car: '83 Camaro
I will get some better pics tomorrow.
Old Nov 9, 2006 | 05:21 AM
GM-LSX's Avatar
Car: Pontiac Firebird T-Top
Engine: V6 3.1 170HP and LSX swap in mind
Transmission: TH700-stock
Axle/Gears: 3.23 -stock
0,4" less for the Corvette Ballancer.
Old Nov 9, 2006 | 06:16 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
I installed that kit on a customer car today and all i have to say is that i had nothing but problems plus the vague instuctions didnt help either
Old Nov 9, 2006 | 07:44 PM
Red92RS's Avatar
Car: 1992 Camaro RS
I was suprised with the hand written directions also, thanks for putting it on though Jay(xtremeirocz), now I can take the car on trips during the summer.
Old Nov 9, 2006 | 11:26 PM
StevenK's Avatar
Car: 91 Z28
Axle/Gears: 3.73 Hawks 8.8
When I got my fuel regulator kit from FBM the instructions were a very crappy hand writen drawing as well.
Old Nov 10, 2006 | 01:27 AM
What kind of problems did you have, other than the instructions?
Does anybody else make this type of bracket?
Old Nov 10, 2006 | 06:55 AM
the main problems i had were that the holes werent drilled straight, the directions , now thats a nother thing, it would seem if they are selling this bracket to the masses they would atleast have printed directions. Daniel, all i know is your car runs great, owen got tunning on it and man that thing flies. I got the bracket and ac stuff on yesterday. and I think you will be happy when you drive it sunday. p.s. everyone on this thread talking about this bracket system, I had to try 5 different belts from oreilly to find the correct one, the belt that was sent from f-body does not fit a stock ls1 underdrive, i think they should tell when yall order it that it doesnt or atleast it didnt fit daniels car, atleast a inch too short
lets just say i had problems and it turned a 20 minute project into 4 hours
Last edited by xtremeirocz; Nov 10, 2006 at 06:56 AM. Reason: Automerged Doublepost
Old Nov 10, 2006 | 04:52 PM
dingle's Avatar
Car: '83 Camaro
Looks like the spacers are just under an inch. There is nothing from the third gen even remotely near that area except for the AC. Maybe the bolts on the back of the AC compressor that hold it to the backet could get in the way?
Like I said before, I had to add a shim on mine or the belt would start to walk off the AC compressor (pics earlier in thread)
Old Nov 10, 2006 | 08:45 PM
You are the man. Thanks for your help.
Old Dec 1, 2006 | 09:24 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Other than the shoddy instructions, wrong sized blets, and having to shim it, is the part worth better than the frustration from the other methods? Would you go this route if you had it to do again?
Old Dec 1, 2006 | 09:51 PM
Red92RS's Avatar
Car: 1992 Camaro RS
xtremeirocz did mine and all I know is that it gave him alot of problems, I got your pm and it is the fbody motorsports bracket.
Old Dec 1, 2006 | 09:54 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Ok, thanks. I didn't want to bug you, but I figured I as someone who has one.
Have you had any trouble with the part since it was installed? I mean, any slipping belts or breaking parts?
Old Dec 1, 2006 | 10:06 PM
Red92RS's Avatar
Car: 1992 Camaro RS
i believe he had problems with it throwing belts, but right now it is back in the shop so they can recharge the ac and fix some small things so i will let you know probably by next week how it works out.
Old Dec 1, 2006 | 11:07 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Ok. Awesome. Thanks.
Old Dec 2, 2006 | 07:24 AM
after trying 2 or 3 belts , we had 3 people , yes i said 3 people help to get the belt that came with the kit on it. That setup seriously has no room for error
Old Dec 3, 2006 | 03:31 PM
dingle's Avatar
Car: '83 Camaro
If I were doing it again I would use a 4th gen A/C system rather than the third gen. I am using the belt that came with the kit, the only thing we had to do was find the right size shim and the right position. I get a little belt slap if you go WOT from low RPM due to the high tension buildup, but once the shim was put in there I have not had a belt come off at all (so far). Oh and the kit belt fits fine for me, I can put it on by myself fairly easily.
Another problem not mentioned in here is my car is an '83, the FBodymotorsports kit is designed for 88-92 models so I ended up buying an A/C unit from them for $100. So the total cost for me was $400. That is not documented anywhere except for right here. I had to call them to find this out. I suggested they add it to the webpage, but they never have.
Old Dec 4, 2006 | 07:12 AM
Didnt know that
my86bird
Oct 23, 2015 12:20 PM
tonys91rs
Oct 10, 2015 03:31 PM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
85Special
Sep 3, 2015 04:21 PM
