No buffer box = No speedo; whats the solution?
Old Nov 26, 2006 | 09:24 AM
mateo's Avatar
Car: 90' Trans Am
Engine: 94' LT1
Transmission: Built 700R4
Alrighty, Ive had a few posts about my problems here and there but Ive looked into it a lil more and here is what Im putting in...
I have a 4,000 pulse wire hanging from the PCM plugging into nothing I have a speedometer that does not work and I noticed that I do not have a yellow buffer box..
I got a buffer box from the upullit but have no idea how to connect anything...keep in mind I didn not do this swap it was done by the previous owner...I do not needa speedometer but it would be nice since Im always pulled over....I took some pics of what Im dealing with if anyone needs it but Im pretty sure some of you guys who have done the swap can walk me through it...
spec wise Im running a 93 LT1 and a 90 700R4 which is the same trans they used in the 93 LT1....all of this WILL work without any mods Im 100% sure...I just dont know what to plug/connect where.
Old Nov 26, 2006 | 11:58 AM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Last edited by bingo; Nov 26, 2006 at 06:58 PM. Reason: deleted bcause of wrong info.
Old Nov 26, 2006 | 04:15 PM
mateo's Avatar
Car: 90' Trans Am
Engine: 94' LT1
not sure what C207 is but im assuming its the big connector with the A-whatever letters....well at K there is no tan wire....its just empty?
Old Nov 26, 2006 | 06:56 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
I am not sure which pin it was. I went out and looked at mine and mine is pin D and is going to be brown or gray. My previous post was based on notes for another project. Sorry.(C207 is the connector under the passenger side of the dash)
Old Nov 27, 2006 | 11:05 AM
silverta8702's Avatar
i just took the green with black wire from the dash wich is plugged into the stock ecm wire harness and hooked it directly to the computer output from the new engine computer , it reads 100 percent correct . the buffer box it only for cruise controll i believe
GTAman
Jul 3, 2024 07:29 PM
Nervous2
Oct 8, 2015 10:53 PM
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
83 Crossfire TA
Sep 18, 2015 12:01 PM
TrevinE
Sep 14, 2015 03:20 PM
