oil pressure and coolant temp Ls1
Old Feb 19, 2007 | 11:54 AM
Blkdth87's Avatar
Car: 1989 TRANS AM
Engine: 2004 GTO LS1
Axle/Gears: 02 ws6 torsen diff 3:42
curious on how you people set up your coolant temp and oil pressure guages.
Old Feb 19, 2007 | 09:14 PM
dingle's Avatar
Car: '83 Camaro
I did all after market (autometer) gauges. Temp I used an adapter and plugged the sender directly into the block on the rear passenger side. Oil pressure sender came with the oil pressure gauge and plugged right into the oil pan.
I orginally had them both hooked up to the stock gauges and they seemed to work fine. The temp was accurate, but the oil pressure was kinda off but it still functioned enough for general use.
Old Feb 19, 2007 | 11:25 PM
Blkdth87's Avatar
Car: 1989 TRANS AM
what adapter did you use? did u use the original coolant temp sensor, or a different type? i really would like to use my stock gauges. and i definetly don't want to drive my car on the street without being able to view coolant temp, especially since ive still yet to drive the car far with the new swap in. i've been using my scanner to view data until i can get my guages to work.
Old Feb 20, 2007 | 09:07 AM
dingle's Avatar
Car: '83 Camaro
You might get the stock sender to fit but I don't know what adapters you will need and how easily it will fit back there.
I used this...
http://store.summitracing.com/partde...?part=ATM-2259
with this
http://store.summitracing.com/partde...0&autoview=sku
It was accurate on my stock '83 gauge.
Old Feb 20, 2007 | 09:26 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
I used an autometer mechanical and drilled out the small fitting just above the oil filter. Its already the correct size hole for 1/8 NPT so its uber easy.
I didnt want to run my factory tach with an adaptor. Figured the calibration would never be right on the stock 20 year old tach and with the kind of RPM i'm running I dont want errors leading to *KABOOM*. So I bought the pimped out Ultra Light Pro comp with shift light and seeing as my oil gauge is inside my factory tach I bought the matching mech autometer one for 35 bucks new. The electric one is waaay over a hundred bucks ( at least the ultra light pro comp is ) and I dont really like electric oil pressure gauges.
I had a bunch of aeroquip braided SS 1/8 line so no worries of the crappy nylon tube melting or bursting. i would never run that nylon junk its not safe. Mounted it with my shift light right under the dash beside the tach in the little pocket there between the ac duct and the tach. Looks sweet if I do say so myself.
Heres a link with a pic on the bottm of the fitting i drilled out
http://www.ls1tech.com/forums/showpo...49&postcount=5
Old Apr 12, 2019 | 07:45 PM
85RS's Avatar
Car: 85 Camaro RS
Engine: GEN I sbc 5.7, .040 over
Transmission: 700R4 Slushbox dreamkiller
Axle/Gears: 3.42 posi
Re: oil pressure and coolant temp Ls1
[img]https://dingle.ls2.com/Pics/gauges_installed 002.jpg
[img]https://dingle.ls2.com/Pics/gauges_installed 004.jpg
[img]https://dingle.ls2.com/Pics/gauges_installed 005.jpg
I know this is an old thread but I noticed you reused the stock bezel, did you use 1¹/²" and 4 ³/⁸ gauges and if so did you have trouble with fitment (touching each other, not fitting behind the cluster, etc.)? Tia, nice install.
89GTAOz
May 16, 2020 09:31 AM
Bstrang6
Sep 8, 2015 04:29 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
