subframe connetors for ls1 swap?
Car: 1989 TRANS AM
Engine: 2004 GTO LS1
Axle/Gears: 02 ws6 torsen diff 3:42
ok, i picked up a set of i think bmr subframes awhile back, and was goin to install them, looks like now thanks to the hawks ls1 ypipe, i have no room for them, anyone got ideas? different subframe connectors? i don't really feel like changing my ypipe / tranny crossmember unless completely necessary.
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Re: subframe connetors for ls1 swap?
I went with Spohn. They follow the rocker panels on each side. They dont go near the tranny tunnel or the exhaust. The fit was awesome.
Car: Camaro
Engine: 6.2L
I have SSM/kenny brown knock offs ( I knocked em off LOL ) but SSM if you can find them are very VERY nice connectors. They are boxed, tie into the rear suspension, and weld in all the way down the rockers and floors with no ground clearance lost or interference at all with c mem or anything for that matter.
Car: 91 Firebird
Engine: 6.0
I wouldn't use BMR SFC's
I used them on my last build, and the fit isn't that great. They do not follow the rocker at all, and you can see them from outside the car. Yeah, its *that* bad. Plus the loss of ground clearance......
I would use Spohn, UMI, SSM, etc
I would avoid the BMR's........
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
we ran the bmr w longe tubes in our lsx swap they fit just fine and you cant see them
SFC009Boxed Subframe Connectors for outside framerail exhaust$199.95 pr.
Transmission: 4L80E/4L80E
I used Spohn in one car and UMI in the other. I assume you'll be running custom exhaust, so the exhaust interference I had with the Spohn's and the Hooker 2055HKR y-pipe wouldn't be a problem, and I'd recommend them for fit. The UMI's are okay, I like their saddle connection to the LCA bracket better than the Spohn single-side interface, but the UMI's don't fit as snug up to the floorpan as the Spohn do.
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I have the Competition Engineering wel ins and they are great, out of the way for a full length setup with Y pipe. Priced right and pretty strong.
ambainb
Apr 25, 2016 09:21 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
