LS2?
Old Apr 22, 2007 | 12:52 PM
88-I.R.O.C.'s Avatar
Car: 1988 IROC-Z
Engine: LS2
Axle/Gears: Strange 60 3:73
LS2?
Anyone put an LS2 into a third gen? I kinda want to do it
I think i can get one + t56 from a 05 gto - Thoughts?
I guess it has electronic throttle controle, so i don't know how that will work...
Old Apr 22, 2007 | 07:26 PM
Legal Disaster's Avatar
Car: 1986 Iroc-Z
Re: LS2?
there's a guy a10beav on here that has done the same thing. do a search for him and you will find alot of info and pics.
Old May 5, 2007 | 05:27 AM
A10Beav's Avatar
Engine: LS2
Axle/Gears: Moser Ford-9, 3.50
Re: LS2?
Yea, I did the swap with an engine from an '06 GTO. All the tips and tricks you'll find for teh LS1 swap will work with the LS2. You don't have to use the electronic throttle either, just get an LS1 F-Body or '04 GTO ECM.
The kicker is that all the wires/harness' have to match, so you'll want a harness and coil packs for the cable/throttle cars. I had problems getting the car to run because of at least 3 versions GM made for coil packs, and they all have the same connectors. If you do it with used parts, then get the engine and tranny from one car, and the harness and coil packs from another.
Good luck!
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BDR
Nov 7, 2015 03:05 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Thirim
Aug 13, 2015 03:09 PM
92GTA
Jul 12, 2006 02:57 PM
