5.3 truck engine in my 87 camaro
Old May 14, 2007 | 10:46 AM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
I've come across a 5.3 truck engine for a grand! Comes with everything I would need to get it going. Engine, harness, accessories, computer. Basically a complete pullout minus the trans. I'm wondering if anyone has ever done this swap using the truck harness ect. If so could you guys give me the wiring diagrams for the truck. By the way I started with a carbed car put a tpi unit in from a 86. Built a 355 under it with vortecs and a 700r4 trans. I'm going to part out all of these parts. The engine only had 600 miles on it and I spun a bearing(oil pump screen fell out). trans has 200 miles on the rebuild and has aluminum pan. I will begin dismantling this combo next weekend. I need the wiring pinouts on the truck harness and everything. Please help me out with this. Some of you may remember me talking about my other combo. Thanks fellow third genners!!!
Old May 14, 2007 | 12:12 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Re: 5.3 truck engine in my 87 camaro
you'll want to begin reading over at ls1tech.com and also http://www.performancetrucks.net/forums/ . Good info there as well. I'm going to be doing something similar to what you're doing though in the future - either a 5.3 or 6.0 depending on what falls in my lap.
Old May 14, 2007 | 12:17 PM
Engine: 5.3L
Axle/Gears: 3.42LSD
Any other resources???? The network at my job won't allow me to access these two sites. Help me out guys.
Old May 14, 2007 | 06:34 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Your gonna have a very VERY hard time if you cannot access LS1tech. I wish i had better or more helpful news for ya there bud but i dont. Good luck!
Old May 15, 2007 | 07:23 AM
Engine: 5.3L
Axle/Gears: 3.42LSD
I can get it at home. I just can't access it at work. When I'm at work I can print out
Old May 15, 2007 | 08:00 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
LS1tech will be your best source to get the info on this motor. You could always cut and paste into word and print it out at work.
Old May 15, 2007 | 06:01 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
If you can get it for a grand I would say do it. If it falls through gofor a 6.0
jhawkeye
May 25, 2022 06:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
