Last wiring Question
Car: 1989 Trans Am
Engine: 94 383 LT-1
Transmission: Tremec 3550
As I have figured out every wire except for the vats and 1 wire on my c100 I have to ask about them.
First off C7 on my c100 (92 RS) is black/white and says engine. Any idea what this is?
Any insight into VATS would be helpful but I'm sure I can piece it together from the diagrams I found.
Thanks in advamce
Thanks in advamce
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
Re: Last wiring Question
www.shbox.com has the LT1 wiring. I used the LT1 vats box, resistor bypassed it, and wired it up. Simpler to do than reprogramming (at the moment).
Car: 1989 Trans Am
Engine: 94 383 LT-1
Awesome, thanks for the info!
Anyone have any idea what that C7 is for?
Could it be Check Engine light? I know that is suppsoed to come fomr the PCM but could it also come from some under dash sensor?
