FM Turbo on Thirdgen LSX (Who's done it?)
Old Aug 23, 2007 | 03:46 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Anyone have one in the works or finished? I'm thinking hard about selling my R6 to fund a Turbo Set up this winter. If you have, were you able to use the truck manifolds or was the steering box in the way? Looking to do the cleanest swap possible without cutting anything out of my car(will consider removing or cutting trays since they are easy to replace). Also know I will have to remove the front bumper support for the intercooler. What probelms did you run into while fabbing it all up?
Old Aug 24, 2007 | 12:00 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Re: FM Turbo on Thirdgen LSX (Who's done it?)
Look for a guy named 25thredrs. I believe he did his with truck manifolds. I plan on doing the same thing. Search for 25thredrs. He is on this site and on ls1tech.com.
I have a 91 RS in case you wanted to know. Im building a 408.
Old Aug 24, 2007 | 04:22 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Thanks for the info, I checked out his swap.
Old Aug 24, 2007 | 06:10 PM
6.LIROC-Z's Avatar
Engine: 6.0L LSX Carbed
Axle/Gears: 3.73 Strange 12 bolt
Come on JT dont turbo that car just to out run me. J/K. I have a set of truck manifolds I will donate to the cause if you end up doing this swap.
Old Aug 24, 2007 | 07:04 PM
jtmiller92's Avatar
Car: 1992 Camaro RS
Engine: 415ci LS3
Axle/Gears: 3.89
Dont worry Bryan, your safe for now. lol I would like to borrow the manifolds though, want to see how well they will fit. Just looking at options right now. If I go turbo it will have to be an extremely clean set up, nothing cut up or thrown together. Guess we will see what happens this winter.
Old Aug 26, 2007 | 03:25 PM
sp63
Guest
Posts: n/a
well i AM doing the turbo swap. 71mm turbo on the 355 in my garage.
ill be back in lex soon enough.
<guy with the blue wingless 92 rs. lots of nitrous ....
Old Aug 26, 2007 | 11:10 PM
super_kev's Avatar
Car: '85 TA
Engine: Aluminum Fuelie
Transmission: Mother of All Manuals
I'm thinking about it, but I don't know if I would be able to do it while keeping A/C, and without cutting the trays. I'd want to do twin low-mount turbos in back, similar to a Gen-TT setup, as it would keep a lot of heat out of the engine bay. However, the 4th gens have more room under/behind the motor, so I don't know if it would work. I'll probably try it in a few years once I'm done having fun with my LS1.
Old Sep 11, 2007 | 10:14 PM
qualls86ta's Avatar
Car: 1986 Pontiac Trans Am
Engine: Forged H/C LS1
Transmission: TH350
Axle/Gears: 10 bolt 4:10
I think somebody is tired of being the slowest third gen ls1 in Ky
Just kidding with ya jt
Terrell351
Jun 13, 2021 01:13 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
PestilenceIV
Aug 20, 2015 03:32 PM
AkDrifted
Aug 17, 2015 07:45 PM
