ls6 $1800
Old Aug 29, 2007 | 08:19 PM
84bandit's Avatar
ls6 $1800
Is this a good deal, ls6 complete motor, wiring harness computer fuel lines, ps pump, ac and accessories for $1800? this was in my local trading post the other day and it caught my eye guy also has the auto tranny for the motor, and he wants $1000 for it
Old Aug 29, 2007 | 08:25 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Re: ls6 $1800
so 2800 for ls6/auto? Yes good deal.
How many miles?
Old Aug 29, 2007 | 08:29 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
Re: ls6 $1800
i paid 2500 for an 01 ls1 minus a few bolts for the accesories and thought i was geting a goot deal. so yes
Old Aug 29, 2007 | 08:33 PM
84bandit's Avatar
Re: ls6 $1800
didn;t say on the miles, i want to build another car and was checking out the ls1/6 swap, at first I was thinking a turboed v6 or small block, but i think that if this setup is still around when the funds are raised, im going with this,
Old Aug 29, 2007 | 09:11 PM
Camaro0605's Avatar
Car: 1991 RS
Re: ls6 $1800
Aren't LS6' only in corvettes?If so is it coming with corvette accesores, manifolds, wiring, oil pan??
Old Aug 29, 2007 | 09:28 PM
ecetim's Avatar
Car: 92 RS B4C - needs lots of work!
Engine: 5.7L L98
Transmission: 700R4?
Re: ls6 $1800
It is a very good price. A couple points:
*I hope other oil pans bolt up, and they should, but you probly can't use the Corvette one
*LS6's are drive by wire - you'll either have to deal with installing a pedal with throttle sensor or change the throttle body to cable-type. Custom programming required to change over too.
*You need to check miles and probably be a good idea to check compression on the motor. For that price you can afford to rebuild it and assuming nothing is busted, still come out cheaper than most setups going for.
*Did LS6's COME with an auto? LS6 came in the Z06 which didn't have an auto; it did come in some Caddy's, but I think those were all CTS-V's and weren't those 6-speed only?
If a deal seems too good to be true, it probably is...
Old Aug 30, 2007 | 08:16 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: ls6 $1800
LS6 is a corvette motor.
the corvette oilpan, and accessories will have to be swapped for Fbody ones.
the corvette uses a transaxle.. so that wont work for you either.
so, on that note, its either not worth that price because it needs too much stuff swapped around to work, OR, its not a LS6 but a 2001-02 LS1 with an LS6 intake and possibly a LS6 block... or its straightup not an LS6 anything
Old Aug 30, 2007 | 08:26 AM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Re: ls6 $1800
Get us pics or part#. Ask him to give you the # of the block. Heads should be casting #243.
Old Aug 30, 2007 | 08:53 AM
ecetim's Avatar
Engine: 5.7L L98
Re: ls6 $1800
LS6 was used in the Caddy CTS-V's as well. It uses a transaxle huh? You mean it has a rear mounted transmission? It's still an LS motor and you can use any LS1-style T-56.
Old Aug 30, 2007 | 09:32 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Re: ls6 $1800
yup, all the C5s and newer Ybodies use a torque tube and transaxle.... its still a T56 or a 4l60e trans... (or the newer 6spdautos)...but in transaxle form
Old Aug 30, 2007 | 09:15 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Re: ls6 $1800
V's used a "standard" T56 tho, not the transaxle type.
Old Aug 30, 2007 | 09:19 PM
vwdave's Avatar
Re: ls6 $1800
IIf a deal seems too good to be true, it probably is...
Exactly. I was offered the same deal (Just $2000 instead) and came to find out the engine was apart of a insurance scam. Needless to say I walked away from that deal as fast as I could.
Old Aug 31, 2007 | 03:26 PM
socal's Avatar
Re: ls6 $1800
the ls6 is just the block, heads, cam, and intake everythig is inerchangable. some ls6 blocks are in camaros and firebirds as well but with ls1 heads and cam, but ls6 intake thay are 01-02. and everything will swap an f-body oil pan will be needed as well as pick up and windage tray but the accersories from anything will work.
Old Aug 31, 2007 | 04:55 PM
Camaro0605's Avatar
Car: 1991 RS
Re: ls6 $1800
Yes accesories will be fine. I think they are actually better from the vette since the alternator is up top and not on the bottom of the engine. However the A/C compressor sits a little farther back and is a little more difficult to use.
Old Sep 17, 2007 | 12:02 AM
Kandied91z's Avatar
Re: ls6 $1800
lsx anything for around 2500 is a good buy if it's all there and in running shape. they are getting cheaper everyday though. around here the motor itself is going for 1-1200 and then the computer, harness and trans separately of course.
when i did mine i paid $3600 for motor, trans, harness, ecm with 35k miles. then i paid another 2k for the accessories i needed to bolt it all up. this was not including the custom 1200 front k member, a arms and mounts either.
now that i've done a few of them though i can cut costs considerably... first time around is always the worst.
Old Sep 18, 2007 | 11:30 PM
CrabhartLS1's Avatar
Re: ls6 $1800
If it's really an LS6 block then yeah awesome deal. If it's someone trying to pan off an LS1 as an LS6 block then it's still a pretty good deal.
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
Buggy Disaster
Sep 22, 2015 01:15 PM
sandman92084
Sep 12, 2015 10:27 PM
