Header clearance issues
Old Sep 17, 2007 | 07:44 PM
inuyasha_lost's Avatar
Car: 92 Camaro RS 25th Anniv
Engine: 93 LT1 w/Vette Access
Axle/Gears: 97 T/A w/3.42 posi
So I finally got my headers installed. Using the Hedman with the D-ports. And I have 1/8" clearance near my brake lines, and near my air box with my evap-core. Does anyone else have this issue? Do you have any issues with heat? How did you rectify this problem? Thanks again.
Old Sep 18, 2007 | 10:49 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Header clearance issues
I'm not sure which Hedman's you are using but mine were also very close to the brake lines. I had to carefully bend my brake lines away from the headers. You really, really don't want them close to all that heat!!!
Old Sep 18, 2007 | 02:22 PM
LT1powered89's Avatar
Car: 1989 Chevrolet Camaro
Axle/Gears: 2000 rear, 3.73, auburn locker
I used the same ones with the same problems. My passenger side header actually melted a very small part of the heater box when I first got the car running.
Old Sep 18, 2007 | 03:06 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Sounds about right, mine is close to the evap box and brake lines, haven't had any problems yet.
Old Sep 18, 2007 | 04:14 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
On my LS1 the header is close to the fuel and brake lines. Not close to the HVAC box... But Ive never had a problem with the lines. I took it to the outer banks this summer. Bout an 8 hour drive no stopping except for gas. And never had a problem. If you are worried, wrap the lines in whatever your favorite heat wrap is.
J.
Street Lethal
Apr 30, 2019 12:14 PM
evilstuie
Feb 28, 2016 03:33 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Wesly_66
Aug 26, 2015 09:55 PM
sreZ28
Aug 14, 2015 07:48 PM
