How many LS1 conversions started with a carb car?
Old Oct 17, 2007 | 12:53 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I may be wrong, but it seems most of you converted an EFI car to LS1.
Not sure how much difference it makes. One difference is the fuel line comes up to the engine compartment on the passenger side. Also no electric pump wiring/relays/etc.
Old Oct 17, 2007 | 12:57 AM
Diabloformula's Avatar
Re: How many LS1 conversions started with a carb car?
I put an LS1 in a 84 carb'd Z28, used a 4th gen plastic tank and built my own fuel lines from the tank to the rails. I also used the racetronix fuel pump kit which comes with it's own harness, fuse, and relay.
Old Oct 17, 2007 | 07:57 AM
five7kid's Avatar
Source & p/n for that kit? Did a search, don't see one that includes the relay.
I'd prefer doing an external pump so I don't have to mess with the tank. I believe the fuel rail can be switched from side-to-side on the engine so the inlet is on the passenger side - no need for new lines.
Old Oct 17, 2007 | 09:05 AM
I might be wrong but I don't think you can rotate the fuel rail on an LS1, The website for the fuel pump is www.racetronix.com.
Old Oct 17, 2007 | 11:44 AM
five7kid's Avatar
I found their website, and looked at a bunch of links, but didn't find anything that included relays. All of the pumps appeared to be in-tank replacements.
Old Oct 17, 2007 | 12:12 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
check my thread out... my car was carbed, and i diddnt change any of the fuel lines... and everything is still on the passenger side
I put my regulator on the passenger side and bent my lines up to it and used the necessary fittings for line sizes on it... I also installed my fuel rail the opposite way so the nipple is on the passenger side. with a compression fitting and a an/pipe adapter the braided line goes right off the regulator and into the rail.
I used an inline aeromotive fuel pump and two inline (10 micron and 100 micron) fuel filters and used my stock tank.
For wiring I sent my wiring harness to speartech and he removed all of the unneeded wires, and made fan relay pigtails, wired in a standalone fuel pump relay and pigtail, and it has its own fuse block. All i had to do was run the wire through the car to where i located the fuel pump, wire up the fan relay in the stock position, and power the harness. Fuel pump works just like a factory one.
He also brought out wires for the guages in the dash. I opted for aftermarket autometers, instead of digging the old wiring out just to use stock guages. My aldl is in place and everything looks like its supposed to be there
Old Oct 17, 2007 | 01:01 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
I went from factory carb. I made my own harness from a 4th gen LS1 harness and my stock one. I used the factory third gen harness for the chassis power and the 4th gen harness ( fuse box relays, everything ) for the engine and accessories.
Old Oct 17, 2007 | 04:00 PM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
I did just as cam did. Got mine running great. It's only about 8-10 wires you will have to connect. Use the ls1 fuse box. I of course did a 5.3 from a truck with the truck harness and fuse box.
Old Oct 18, 2007 | 12:33 AM
five7kid's Avatar
Cool. Good to know I'm not alone.
I'd forgotten what it was like to drive an LG4 car - and I'm driving it at sea level right now, not 5800' like I was 8 years ago. It's going to be sweet having the LS1/T56 - car won't know what hit it. . .
Old Oct 18, 2007 | 08:13 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
well its been so long since i drove my car with the lg4 in it, but i do know where you are coming from
if you have questions or anything i can help with just pm me
Old Oct 18, 2007 | 09:35 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Yeah...I went from my head/cam ls1/t56 to an LG4/auto...try that step down. Car feels like an absolute slug.
And trust me. The car WILL know what hit it. More than twice the power.. So be prepared to slap some SFCs on it, and upgrade the rear end and rear suspension so you can make some use of that new umph
J.
Old Oct 18, 2007 | 09:41 AM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
??? Did you buy another car? You are going to fix your GTA I hope
Old Oct 18, 2007 | 09:45 AM
five7kid's Avatar
Oh, all of that is on the list. I figured that stuff out with the first Camaro. I think you'll find some of what I'm going to do "interesting" - but I won't spoil the surprise. As they say, "Film at 11."
Old Oct 18, 2007 | 02:19 PM
Car: 86 Trans AM
...Its not looking good. Its just a TA...and there was enough issues up front for me to not want to deal with. I havent ditched it... but I couldnt pass the deal up that I got on the 86. Its not too late to fix the black one...but its on hiatus for now until I can make my mind up
J.
Old Oct 23, 2007 | 04:34 PM
TMoNeE's Avatar
Car: 87 Z28
went to lt1 from 305 carb
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
stalkier
Aug 7, 2015 04:49 AM
L98GTA87
Aug 5, 2015 11:02 PM
