Painless engine managment for LSX
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
Anyone hear about the engine mangment system from painless for the ls1? its a perfect hi-rpm kit. comes with hydraulic cam, ecm and harness. Supposedly supposed too get you 409hp/407lbsft with good fuel economy. Just wondering if anyones heard of this are if anyone has this and if its any good.
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: Painless engine managment for LSX
You can get that amount of HP out of the stock PCM system with heads/cam, why pay the outrageous prices of Painless for the same thing.
ya i dont even know the price for it i was just wondering if anyone had it. ya a cam and reprogrammed ecm could probably do it for ya. heads arent that cheap thou
Car: 1987 GTA
Yeah, heads can be bought for an LS1 cheap...about 1300 for a set of Patriot heads which are extremly good heads for an LS1. Those are stage 2 heads.
We use a new GM raw 035 casting.
Precision welded combustion chambers.
Heat treated to OEM specs.
5 axis CNC machined.
Hand detailed and assembled.
21-4N Stainless Valves
Bronze Guides
Patriot Gold .650" Dual Springs
Titanium Retainers
5 Angle Valve Job
Bronze Guides
Titanium Retainers
5 Angle Valve Job
well 1300 can be defined cheap too the older crowd but too a kid with hes first 3rd gen working at taco bell sees those heads as hella expensive lol. Me personally ive been looking at the trick flows i havent decided wut mods are going on my ls1 before i put it in yet i want over 400hp for sure no compromise trying too retain good gas mileage i got a pretty long commute each day.
Car: 1987 GTA
If it's a 6-speed, then you'll be pretty much set. I know guys running 500 to the wheels getting 27-28mpg with 3.73's
LS1's are wierd how you can make hella power and still get good gas milage, not like your standard SBC. My LT1 in the GTA is the same way, build the fool out of them and get 26 or so with 400 to the wheels.
ya they really did somthing right with the new engine designs. If you know what there set up for 500 with that mpg i would love too know it. Im just trying too stay as far away from radical cams that i can you can make a engine that has 1000hp the trick too keeping it tame is a tame cam. well i should say the only way too get the 1000hp with driveability is boost and a tame cam lol itd be expensive.
Car: '83 Camaro
Transmission: 4L80E/4L80E
$799 plus shipping.
$889 if you go for A.I.R. tubes & 3" collector.
once u finally get it all together thou and sit down in that driver seat and go WOT you forget about how much you just spent lol.
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
eightsixseven
Dec 16, 2024 01:50 PM
Fast355
Dec 2, 2016 06:33 PM
