t56 crossmember?
Old Nov 5, 2007 | 09:15 AM
92ZZ3RS's Avatar
Car: 92 camaro rs
Engine: LS1, 426 rwhp 406 rwtq
Axle/Gears: 9" with 3.70's
t56 crossmember?
i have the t56/LS1 conversion sphoon crossmember for my 1992 camaro and the holes are not aligning up right. any ideas?
Old Nov 5, 2007 | 09:17 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: t56 crossmember?
I had to put the bolts in on one side very loose, then put up the other side to get all the bolts started.
Old Nov 5, 2007 | 09:30 AM
92ZZ3RS's Avatar
Car: 92 camaro rs
i did that, but then you can barely even see the holes on the other side. i dont know if they are just drilled wrong or maybe motor is not aligned up right.
Old Nov 5, 2007 | 09:32 AM
kubus_stroinski's Avatar
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
Originally Posted by 92ZZ3RS
i did that, but then you can barely even see the holes on the other side. i dont know if they are just drilled wrong or maybe motor is aligned up right.
The motor is probably aligned properly but the tranny crossmember is just poorly built and in general doesnt fit right. Just keep trying and you will eventually get it to fit somewhat
Old Nov 5, 2007 | 09:35 AM
92ZZ3RS's Avatar
Car: 92 camaro rs
i guess i can always slot the holes out more, but damn. you would think these high dollar swap parts would fit better. but all cars are different.
Old Nov 5, 2007 | 11:17 AM
Klortho's Avatar
Car: 1987 GTA
If it doesn't fit right, you may want to call Spohn about it and see what they say (dont' e-mail, calling is better) And also, it's possible that the body is twisted and the subframes just don't line up exactly like they used to.
Old Nov 5, 2007 | 04:20 PM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
ive had two different crossmembers and i had to barely start all 4 bolts before it would line up... might take a turn at a time but it should go
Old Nov 5, 2007 | 10:15 PM
92ZZ3RS's Avatar
Car: 92 camaro rs
i tried it tonight without the trans mount and the holes match up on both sides. i guess i can drill out the center hole for the mount a little more
Old Nov 6, 2007 | 10:37 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
take the mount and flip it around the other way... if its the lt1 style mount flipping it around will let it slide through the hole on the x member
Old Nov 6, 2007 | 11:03 AM
92ZZ3RS's Avatar
Car: 92 camaro rs
it is a 6-spd out of a 2002 TA WS6. i will try to turn it around though. i didn't even think about that.
Old Nov 7, 2007 | 10:08 AM
ls1>*'s Avatar
Car: '88 Camaro
Engine: LS3
Transmission: Mag F
Axle/Gears: 9" 4.11
mine is also, and i flipped the mount around it it gave me the distance to not have to notch anything
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
kammi10
Nov 9, 2015 08:28 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
