drive by wire + cruise?
Old Feb 10, 2008 | 06:54 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I've searched, but I can't seem to find anything helpfull.
Has anyone ran a drive by wire throttle body and have functioning cruise
control? And if so, how? I think I remember seeing where someone had done, but I can't find it.
I found a setup (pedal, wiring, and throttle body) for sale. I want to run drive by wire so I don't have to run the throttle cables and clean up the engine bay. I just want to make sure it will work with my set-up and have cruise before I buy it.
Thanks in advance!!
Old Feb 10, 2008 | 08:18 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: drive by wire + cruise?
I would say if you use the cruise control module and wiring for a drive by wire setup it would work.
Old Feb 10, 2008 | 08:32 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I saw it on ls1tech.com but I have problems getting there search to work and have to use the google opt. which seams to miss posts
here is one who got it going http://ls1tech.com/forums/showthread...e+cruise+drive
Old Feb 11, 2008 | 10:14 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
So, I'd need the f-body cruise control module and the DBW wiring, pedal, and TB? Or would I need the cruise control module from the same vehicle as the the DBW set-up? From that thread, it looks like I'll need to get a TAC (throttle actuator control) from speartech to make it work. The PCM controls the cruise, I just need to connect it to the throttle body....I think.
Old Feb 11, 2008 | 09:15 PM
Engine: ls1, LB9
from that thread I would just ask speartech. I am too lazy to pull up the schematics but he would know and is very helpful
Old Feb 15, 2008 | 01:47 AM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
it depends on the ecm used like an f-body wont work since it cable and the gto that we used the cruse is in the bcm not the ecm so i think you need a vett ecm and other stuff spearthech did our harness and said our best option was an aftermarket crusie control and run the cable to the trottle pedel call spearthech and ask them
this was something we took into consideration after it was to late.
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
stalkier
Aug 13, 2015 12:59 PM
Bull86
Aug 10, 2015 05:43 PM
