Project: LM7 5.3 Into my iroc
Old Feb 18, 2008 | 01:36 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Hey Everyone.
Well, ive decided to start off my swap. Figure its a good time while i have access to all the machines at school (im only 17) to make up mount's and any other parts ill need.
Here's whats happening:
Motor: '04 LM7
Mod's: LS6 intake, LS1 Cam, LS1 injectors
Changes: F-body Acc, F-body Oil pan
Fuel: PP Billet Fuel rails w/ Return regulator
Mounts: Custom made steel conversion mounts
Exhaust: Stock manifolds, custom y-pipe
Wiring: Modified stock harness
Throttle: DBW & Electonic pedals
For anyone looking to swap a later 5.3 into a 3rd gen, im going to be doing a electonic pedal swap, which ill put info up for. Also note that if your going to be using F-body accessories, you will loose 1 alternator bracket mounting point, and also need to drill & Tap for the 2nd alternator mount (provisions are cast, but not drilled). The trucks & F-bodies share the same alternator dimensions so it iwll bolt into the bracket. You will need an f-body balancer, due to the fact that the truck belt runs about 3/4" further from the motor so the belt wont sit on the balancer.
While im doing the swap, my car will also get an LS1 rear diff, with the LS1 rear brakes, im doin an LS1 front brake swap, and also wiring everything up to the 4th gen dash in my car. The car also has 4th gen exhaust in it, 4th gen driveshaft etc etc. All work towards my "4th gen in 3rd gen skin" project
Here are a few pictures of progress i made today:
Old 305 is out!:
(its was a PITA getting the motor unbolted from that tranny )
New motor on the stand (I pained the block & rocker covers, F-body pan isnt on the motor yet)
And hanging in the engine bay Its certainly not ready to go in yet, but it looked cool hangin there
Ill be updating as i make progress
Old Feb 18, 2008 | 01:58 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Re: Project: LM7 5.3 Into my iroc
Oh, and one more thing. Im planning to re-use my 700-R4. So ill be running a TV cable into the car to attach to my throttle, so when i stomp on it, its pulled.
This is the plan. If it doesnt work out, ill be putting a 4L60e into it
Old Feb 18, 2008 | 02:24 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That requires a spacer, right?
It's a lot more than that. The "TV" in TV cable stands for "throttle valve" - as in, a valve that adjusts transmission parameters based on throttle position. The geometry is critical, so don't just assume that if the cable is pulled all the way at WOT that you're good to go.
Old Feb 18, 2008 | 02:34 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Yep, it requires are .400" Spacer, im still working this out.
Yikes. That wont work then. The electronic throttle body has no turning parts other then the blade inside the body, so theres nothing to hook it to.
Im wonder if its in my best interest to just get a 4L60 e?
Old Feb 18, 2008 | 09:14 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I'm thinking of doing the 700r4 as well with my LS1. I was told I'd need not only the spacer and TV cable kit, but a torque converter lockup controller (B&M makes one) as well as a constant valve pressure kit (http://store.summitracing.com/partde...5&autoview=sku). So....you're looking at $300+ for just the controller and valve pressure kit. Plus the TV cable kit and spacer, etc. The only reason I'm still considering it is I had the 700r4 rebuilt less than 10,000 miles ago and hate to just pull a perfect tranny. If I knew somebody with a good 4l60e, I'd be all over it.
Old Feb 18, 2008 | 09:42 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
I know there is a kit out there to adapt the T.V cable to LS1 throttle bodys... Wait thats electronic right.. Duh. Nevermind sorry. Youll have to go 4l60e.
Old Feb 18, 2008 | 10:06 PM
Car: 1987 GTA
Transmission: 4L60e
Yeah...if you decide to keep the 700r4 - here's the kit you'll need for the TV cable: http://www.tvmadeez.com/ls1_cam/
Old Feb 19, 2008 | 11:25 AM
afida15's Avatar
I think you should be a man and drop a Nice T-56 in there lol. dont have to worry about tearing it up and you get nice gas miliage with it cause it has 2 over drives, and you get the joy of shifting gears.
Old Feb 19, 2008 | 12:40 PM
five7kid's Avatar
Control freak!
Rowing the gears is more fun than practical. There's only been one Ronny Sox.
Real men admit it when there's a better way to do something (can you say, "paddle shift"?).
Old Feb 20, 2008 | 03:26 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Thanks for the input guy's!
Im going to do some research on the transmission deal. If i just need to adapt the TV cable, Space the Convertor, and wire the convertor lockup. Im going to keep mystock tranmission. If its more then that, ill head over to the local boneyard and look for a 4L60e tranny.
Old Feb 20, 2008 | 07:39 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Unless you have a fresh hi-perf built 700R4 I would have to lean towards the 4L60E for numerous reasons. It likely wont cost you a nickel more and you will have tunability and modern tech support available to maximize your returns for swap dollars and time.
Not to mention ( I can speak from multiple *ahem* experience here ) that a 700R4 that works GREAT behind a mild 305 or 350 will turn to shred mighty quick behind any real power.
Plus if your 700 is still a good piece you can sell it.
Old Mar 13, 2008 | 08:32 PM
86IROC-z28's Avatar
Car: 1986 Camaro Iroc Z28
Engine: 325ci. 6bolt skirted main
Transmission: Built stg2 700R4
Axle/Gears: 3.42 Posi disc rear
I just got an LM7 with a bunch of accessories. I am gonna follow you bro so your not alone in this swap.......I plan to run it in my IROC too.
Old Mar 13, 2008 | 08:46 PM
Transmission: 4L80E
Me too! But its an LS1. Vary happy! Start putting it in here in a few weeks. Gettin everything together right now. All have to post as well.
Old Mar 13, 2008 | 09:01 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
I'm putting my 5.3 in soon, and I will have track times too as soon as the track opens.
Old Mar 24, 2008 | 05:36 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Hey Everyone.
Havnt Updated in a while. Well, i went to florida, and took advatage of the non-boarder crossing shipping & summit racing:
F-body pan & stuff:
LS1 Brake adaptor brackets:
Then i did a mockup with the motor:
Made up my hubs:
I did some more work on my iroc today.
Dropped the rear out & sold it, pulled the old tank out & threw it on the lawn and then got my motor back out.
Gotta finish cleaning the one half of the shop to bring the '00 t/a donor over for its rear diff & tank.
The engine bay has been cleaned and ill paint it this week. Heres some shots of work:
Stupid previous owner cut the car to drop the tank (took me 45 minutes to drop the rear, pull the exhaust and drop the tank)
Motor, in all its glory, patiently awaiting to be finally running again
Im a pretty Cleanly worker
Old Mar 24, 2008 | 06:15 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Oh, and for the tranny, i just ended up going for a 4L60e
Old Mar 24, 2008 | 06:22 PM
Transmission: 4L80E
Loks like your car blew up in the one pic..LOL. Good work! I'll soon be starting my swap. Already put on my C5 Brake upgarde and ZR1 wheels.
Old Mar 24, 2008 | 07:14 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Lookin good! To bad the weather aint... More snow.. bleh ...
Old Mar 25, 2008 | 09:58 PM
86IROC-z28's Avatar
I have a question about engine mounts, you said you made them right? you have any pics?
Old Mar 25, 2008 | 10:19 PM
Car: 1987 GTA
Transmission: 4L60e
I'll let you know how keeping the 700r4 goes. I've got my TV cable kit, spacers, bolts, and am ordering the lockup controller. I believe the TV made EZ kit negates the need for the full pressure valve body. These combined with tuning the computer for the older vss should all work out. On a side note - what vss pulse per mile does the new 4l60e use? I wouldn't mind changing the vss out and /not/ changing the computer if that's possible too...
Old Mar 26, 2008 | 06:26 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Im not using the 700-R4 because im using a Drive-By-Wire Throttle body. The PPM from the 4L60e's are 4000, i beleive thats the same for all of them.
Ill snap a few pictures tonight. I made 2 sets of them and i wont be using them. Their made of 6061 Aircraft Grade Aluminum, to the exact spec's of S&P's mounts. Let me know if you would like a set.
Sheldon
Old Apr 1, 2008 | 07:56 AM
86IROC-z28's Avatar
why wont you be using them?
Old Apr 1, 2008 | 02:41 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
I Made every style of mount and decided id use whichever i liked best. Im using the Horseshoe strap setup as it allows me to position the motor as i please.
I made up 2 sets of S&P style because i cut too much metal, so i just made an extra set.
Ill take a shot of them tommorow night when i finish the strap ones up
Old Apr 2, 2008 | 09:28 PM
86IROC-z28's Avatar
cool man. Im planning to pull my 305 this weekend. so hopefully i will have my 5.3 on the stand and an empty engine bay.
Old Apr 3, 2008 | 06:43 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Sounds good!
Heres a few update pictures:
Painted engine bay:
Brake brackets mounted:
LS1 Rear diff painted:
Sway bar & brakes painted:
Old Apr 3, 2008 | 07:43 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Just a verbal update for tonight.
Got the LS1 fuel tank mounted in the car tonight!!!!! Couldnt be happier. Big thanks to Justin (Ghettocruiser) for responting to my frantic IM's when i was having trouble figuring things out!
I modified the LS harness to plug to my thirdgen harness, guess ill see soon if it works or not
We need to get the headers out of the donor car so i can pull the fuel lines then modify them to fit into my car. From there i need to modify the rear brake hardlines to work on a block. Then mount everything up in the rear end. Drop the motor in with my straps/plates & get the mounts made up.
From there im hoping to order the Stainlessworks longtube headers, then ive got wiring.
Ill grab some pictures tommorow night.
Old Apr 13, 2008 | 04:14 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Got some more work done today:
Mounts Tacked in place:
Engine in bay:
Checking how im gonna make a air intake:
Checkin pan clearance:
Waiting for springs to dry from paint so i can finish mounting the rear diff
Old Apr 14, 2008 | 06:41 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Not sure how I missed the thread with pics of your car sheldon! Looking pretty good. Your car looks pretty decent. You seem to be making good progress too.
Keep it up man!
J.
Old Apr 17, 2008 | 09:17 PM
86IROC-z28's Avatar
can you explain to me the fuel system you are using?
i have the 5.3's fuel pump, it came with the crate.
is it going to be a tough task, or will it be simple?
Old Apr 18, 2008 | 12:45 AM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
I'm using a stock third gen pump. should be fine unless you are talking about some serious power. Then you could just upgrade your pump.
Old Apr 18, 2008 | 06:24 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
My fuel system is the tank from a '00 T/a, then modified LS1 4th gen body fuel lines.
Old Apr 20, 2008 | 08:50 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Motor mounts welded up with little supports:
Repainted my motor:
Painted my intake metallic black:
5000km's look like this:
Old Apr 21, 2008 | 08:35 AM
86IROC-z28's Avatar
Not sure if you can help me in this field... but i have this engine with an LS2 intake, also on my way to owning a stock LS2 cam, would this be a good combo for the top end? Should I stick with a 78mm throttle body? I was thinking 90mm would be too much air, and not enough velocity. Anywho, any help would be greatly appreciated.
Later
Old Apr 21, 2008 | 09:17 AM
ssean92's Avatar
Car: sold
Very nice looking good
Old Apr 27, 2008 | 09:06 PM
86IROC-z28's Avatar
hey dude, how are you mounting your alternator and/or power steering pump?
do we need ls1 style mounting brackets?
Old May 4, 2008 | 07:05 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
both are on LS1 f-body brackets. Had to drill / tap one hole in the block for the alternator
Old May 4, 2008 | 07:33 PM
86IROC-z28's Avatar
heres my progress....threw some high temp silver on the block.
Old May 4, 2008 | 09:12 PM
T TA 355's Avatar
How much did you guys pay for the 5.3? Both of your motors truck engines?
Old May 4, 2008 | 10:54 PM
socal's Avatar
Car: 91z,97ws6,98fb,87&90jeep,05 yz250
Engine: 5.0tpi,5.7LT4,5.7LS1,4.2I6,5.7TPI,1
Transmission: t5,4l60e,
i just paid 200 for a complet 4.8 and 400 for a long block 5.3
Old May 4, 2008 | 11:04 PM
socal's Avatar
Later
keep in mind the stock ls2 cam doesnt have the ring for the ls1 cam sensor so unless you switch to the ls2 timing chain and front cover and extend the wires you cant use it. I'm also running and ls2 intake but i'm just going to get the $100 tb adaptor and run the 78mm
Old May 5, 2008 | 06:39 AM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Im planning to run an LS6 cam with my LS6 intake. Ill just run the cam this year, then im going to T-76 Turbo it next year.
Sheldon
Old May 5, 2008 | 09:09 PM
  #42
86IROC-z28's Avatar
so i should find a ls2 timing chain, and sprocket?front cover, like timing cover? i sure do need the help.
Old May 5, 2008 | 09:13 PM
  #43
86IROC-z28's Avatar
should i get this?
http://cgi.ebay.com/ebaymotors/COMP-...m140230144821&
Old May 6, 2008 | 12:45 PM
  #44
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Just get the LS2 chain and re use your stock gears. The chain is fifteen bucks new and its the same chain they use on the C5R race engines that survive the 24 hrs at LeMans. Dont waste your money on those aftermarket chain sets.
Some guys frown on re using the stock gears but I did and so do many others over at LS1tech with no problems. I look at it like this; If your stock chain is not worn out and you want to upgrade for strength reasons then the gears should be fine. Obviously if your engine has a cozillion miles on it and the chain is worn out then the gears are too.
Old May 6, 2008 | 05:27 PM
  #45
T TA 355's Avatar
How much are you paying for the 4L60E?
Old May 6, 2008 | 08:58 PM
  #46
86IROC-z28's Avatar
when i look at the chain its doubled, like double roller. is the 5.3 truck engine a double roller? just trying to make sure i get he right thing.
Old May 7, 2008 | 09:26 AM
  #47
86IROC-z28's Avatar
i paid 700 for a complete 5.3 lm7 with computer and all accessories.
Old May 13, 2008 | 01:50 PM
  #48
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Alright everyone, bit of an update.
I sold my old 5.0L engine from my iroc, but part of the deal was that i put it into his convertible, so ive been tied up with that.
Besides that, the ups guy showed up last night, and delivered a set of professional products red anodized billet fuel rails. They look freakin sweet installed on my metallic intake. Ill post up pictures tonight.
Also bought an LS1 aluminum block/rods/pistons that i will transfer my 5.3L parts too during next winter and build up a LS1/6 engine, aiming for around 400rwhp.
Engine will just be a cam and heads engine. TSP CNC ported stage 1 heads, then a MS3 cam (havnt decided yet)
Will buy a bunch of bends and attempt to fabricate my own headers, or just buy the stainless works headers. Going to leave the boosted idea untill i finish the ls1 into the car, then maybe ill go boosted later.
Read alot of stories about a $3k turbo project ending at $15k. Cant afford that so ill put it on the back burner.
Sheldon
Old May 14, 2008 | 12:57 PM
  #49
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
looking good man your swap reminds me that i need to get on starting my swap in my 86 t/a
Old May 14, 2008 | 09:18 PM
  #50
86IROC-z28's Avatar
damn...nice plans you got there.
