Lt1 swap torque arm
Old Mar 9, 2008 | 03:00 PM
86iroc504's Avatar
Car: 86 Camaro
Engine: '03 4.8 vortec
Transmission: 4l60e
Lt1 swap torque arm
hey how did you Lt1 swappers get your torque arm to mount on, the holes on torque arm does not line up with holes on transmission
Old Mar 10, 2008 | 05:45 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: Lt1 swap torque arm
I used the stock 4th gen torque arm mount and my 3rd gen torque arm.
Old Mar 10, 2008 | 09:14 AM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
did you have to lower or adjust anything to get your mount holes to lines up on both torque arm and transmission. i have the 4gen torque arm mount also.
Old Mar 10, 2008 | 05:50 PM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
hey i see what i have to do. damn, but someone tell me there is another way of putting this thing on, i forgot to put it on when I installed the transmission!
Old Mar 10, 2008 | 05:57 PM
Firebat's Avatar
Take apart the torque-arm-mount(bushing?) on the tranny and their should be about 2 halves.
Take the half of the mount that goes on the tranny and bolt it on. Bolt the actual torque arm on the rear first. Move the torque arm down and put the other half of the torque-arm-mount on the tranny. Torque arm should now be in place.
Old Mar 10, 2008 | 06:28 PM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
my fault for not being clear, I meant I forgot to put the torque arm bracket on the transmission before I bolted it on, and seems there is no way it could go in from the bottom
Old Mar 10, 2008 | 07:13 PM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
anyone knows the easiest way to install the torquearm bracket with the transmission already bolted up without unbolting crossmemeber, and all that stuff.with the screw attached to the torque arm bracket, it seems impossible putting the torque arm bracket on from the bottom!
Old Mar 10, 2008 | 07:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You're going to have to drop the tail of the tranny. Ain't no other way.
Old Mar 11, 2008 | 08:31 PM
86iroc504's Avatar
Car: 86 Camaro
Transmission: 4l60e
I should be able to pull the crossmember and it should sag down some hopefully
Old Mar 11, 2008 | 11:56 PM
five7kid's Avatar
Put a jack under the tranny before you unbolt the crossmember.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
