ls1 806 heads
Old Apr 9, 2008 | 10:48 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
ls1 806 heads
i have a set of 806 ls1 heads, bought a few years back, cant remember what year vetter i believe they came from any idea on what model, and what they may be worth stock
Old Apr 10, 2008 | 05:58 AM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: ls1 806 heads
They're from a '97-98 vette or '98 TA or Camaro, perimeter bolt valve cover, someone on LS1tech just had a set up with 50k miles for 80 bucks plus shipping.
Old Apr 10, 2008 | 02:01 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
Re: ls1 806 heads
yep the perimeter heads were the worst of the ls1 heads
Old Apr 10, 2008 | 03:12 PM
Klortho's Avatar
Car: 1987 GTA
Re: ls1 806 heads
Actually, there are no difference between the 806 and 241 heads on the LS1s. Both flow the same, you just can't get the bling for the perimeter bolt heads.
Old Apr 10, 2008 | 03:18 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Re: ls1 806 heads
no stock ls1 heads are worth more then $100 perimeter or center bolt.
Feels weird to say that an aluminum head that flows 240+cfm isn't worth anything but that's just the case.
Check ebay, all of them are cheap.
Old Apr 10, 2008 | 05:25 PM
1slobird91's Avatar
Car: 91 Trans Am
Engine: 5.7 TPI L98
Re: ls1 806 heads
I would like to make a correction and im probably going to get bashed for this but..
97-98 806: worst flowing LS1 heads
99-00 853: a little bit better flowing than the 806 heads
01-02 241: best flowing LS1 heads
Z06 243: best flow and compression rate out of all of the LS series heads of the 97-02 years.
Old Apr 10, 2008 | 06:03 PM
Aaron91RS's Avatar
Car: RS
Re: ls1 806 heads
no you're right and i was thinking the same thing but didn't bother saying.
Overall though the difference between the 'bad' ls1 heads and good one's is so minimal in stock form it's not worth swapping them.
Old Apr 10, 2008 | 06:16 PM
1slobird91's Avatar
Car: 91 Trans Am
Engine: 5.7 TPI L98
Re: ls1 806 heads
i agree with that...but I sitll would never ever get 806 heads..they are a pain to work with and they look ugly as hell too!
Old Apr 10, 2008 | 06:23 PM
Klortho's Avatar
Car: 1987 GTA
Re: ls1 806 heads
Again, no difference between the flow of the 806 vs the 241 heads. Only thing they changed in the casting was perimeter bolt vs centerbolt.
Old Apr 10, 2008 | 06:32 PM
godreject's Avatar
Re: ls1 806 heads
thanks 4 the replies, i got these so long ago i didnt remember what they came off nor do i know enough about ls1 motors to know a price for them. i figure i need to get rid of them, and was just curious as to what to expect, they've sat in the back of my cars trunk the last few years, so i guess whatever i get will towards my current project, thanks though oh and ebay only had one set of these casting #'s so it was hard to judge thanks though
Old Apr 10, 2008 | 09:31 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: ls1 806 heads
isnt there a "bump" on the exhaust side of the 806 head?
seems i read a thread about a flow debate, and the 806 was only down a few #'s until you took out the bump in the exhaust port, then it actually make better #'s than the 241.
but nobody wants those ugly covers and coils.
Old Apr 10, 2008 | 09:44 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: ls1 806 heads
if you have the covers they can get 50.00 just for those alone
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hayesaw0210
Aug 23, 2015 11:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
