need obd2 port wiring pic
Old Apr 15, 2008 | 10:13 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
I know I saw one but can't find it in a search now.
Anyway I want to take the 99 obd2 connector off and put it in my ls1 car for obvious reasons.
It looks like about 6inches from the main connector some wires go in to a small plastic piece and from there even more wires come out.
So I got some wires going over toward the passenger side dash and some going up toward the gauge cluster.
Do I keep this second little box that adds more wires or do I just cut it behind the connector and rewire it back in?
Whichever way which wires get wired in where?
Old Apr 15, 2008 | 02:48 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: need obd2 port wiring pic
4 wires, orange is power, the blacks on the bottom are grounds, tan is serial data, and one more I believe white/black stripe is also needed. The Tan and white/black are in the blue and white plugs on the LS1 harness but it's possible the tan serial data wire is in the C100 connector on the LS1 harness.
LT1Formula
20
Nov 14, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
Jake_92RS
Aug 11, 2015 10:39 AM
mx127
Aug 10, 2015 08:13 AM
92projectcamaro
Aug 6, 2015 01:20 PM
