LS Crossmember
Old Apr 25, 2008 | 09:29 PM
F-Body Demon's Avatar
LS Crossmember
Can I use this crossmember with a 4L60E?
http://www.skulte.com/product_info.p...products_id/83
Old Apr 26, 2008 | 10:49 PM
Bradlyj8Z28's Avatar
Car: 1991 Camaro Z28
Engine: 2002 SS LS1
Transmission: 6 speed
Axle/Gears: Auburn 3.42
Re: LS Crossmember
That one is for a 6 speed. Heres one....
http://www.hawksthirdgenparts.com/in...OD&ProdID=1348
Old May 20, 2008 | 02:16 PM
Re: LS Crossmember
The one I was looking at is for dual exhaust, trying to avoid a headache here.
Anybody
Old May 20, 2008 | 02:52 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: LS Crossmember
Not sure...but I dont think you can run a double hump with the auto... I know there isnt one out there. So if you want it, you gotta build it yourself.
If you are building everything on your own, then you will avoid headaches by building the crossmember to suit your needs. The aftermarket ones are going to be straight across mostly. And if you want true duals, you'll ahve to pop out around the "chassis rails".
J.
Old May 20, 2008 | 07:13 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Re: LS Crossmember
Your toast with an auto man. There is no way your going between the frame and the trans pan you have to go below the trans cross member with the pipes or cut and rework your frame to clear which would be a nightmare.
Old May 20, 2008 | 07:39 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Re: LS Crossmember
yes with the auto you won't have it all tucked up. I had built one on my 700r4 setup and it worked but it was close.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kammi10
Nov 9, 2015 08:28 PM
tmork454
Sep 29, 2015 06:33 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
luvofjah
Sep 10, 2015 10:41 AM
