my 93 z died
Old May 2, 2008 | 08:50 PM
vtwinsroc's Avatar
Car: 86 iroc,89iroc,98z28
Engine: 305,305,ls1
Transmission: 700r4/4l60e
Axle/Gears: 2.77/3.23
my 93 z died
my bro in law killed my 93 z that was parked so i'm going to put the lt1 inside of my 86 iroc but i've been reading so i have some questions has anyone tryed pacesetter long tubes for the swap can you still use the cat back of a third gen or the fourth and I want the rear end of the 93 will it blot up and will i have trouble with spacing for the rims . do you take the whole relay center from the 93 thanks guys
Old May 2, 2008 | 09:04 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: my 93 z died
Sucks to hear the car was ruined!
The Headers will not fit without serious modification. The Catback however will fit with minor modifications. Ive got a LT1 F-body Magnaflow system in my '89 iroc-z.
The rear differential will bolt in perfectly, however its 2" wider on each side, meaning you need to run 4th gen wheels.
Your best bet is to put as much as the harness as you can into the thirdgen
Fanatic1074
Oct 3, 2022 05:57 AM
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
