A quarter of a millimeter?!?!?!?
Old May 6, 2008 | 08:51 AM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
This has been rattling around in my brain for the last 2-3 weeks, & I finally figured I'd ask you guys about it. While doing research for my swap, I ran across the following quote:
"The bellhousing-mounting surfaces at the rear of the engine block oil pan need to be within--get this--a quarter of a millimeter! Any extension of the pan surface past the block is unacceptable: that is, the pan can sit back from the block as much as 0.25mm, but can't protrude from the block at all."
Taken from this article.
Now ignoring how it seems to contradict itself in the last sentence, has anyone who's had the oil pan off paid attention to this alignment when reassembling it? I figure that I'm going to use a straight-edge as described just in case, but I'm really curious as to what you guys have to say about it...
Old May 6, 2008 | 09:18 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: A quarter of a millimeter?!?!?!?
It makes sense. Wording isnt that great... But they are just saying that the pan cant sit back and stick out from the block any. I have a feeling it has to do with how the pan is sort of structural to the block, and if it sits back, the bellhousnig could contact it. That would either cause teh pan to get damaged, or the trans to not seat totally.
Just my guess though...
Im willing to bet it falls into place pretty easily though. as long as you arent shoving the pan backwards when you are bolting it in, its probably ok... Ill find that out in a couple days here.
J.
Old May 6, 2008 | 12:40 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
The pan is structural on LS engines. The bell housing bolts to it and the rear of the block and if its off by more than 1/4 mm or in normal SAE measurements .0010" it can pull things around in ways that they shouldnt be pulled and will shorten the life of??? Crank? Trans? Block? All of the above??
Not worth chancing just take great care when installing the pan and you'll be fine.
PurelyPMD
May 5, 2016 04:57 PM
jrdturbo
Mar 31, 2016 02:58 PM
LC2 TECH
Oct 13, 2015 11:53 PM
italiano67
Sep 22, 2015 08:42 AM
84 TA NV
Sep 6, 2015 08:02 PM
