winter projects FINALLY done!
Old May 31, 2008 | 11:03 AM
A10Beav's Avatar
Engine: LS2
Axle/Gears: Moser Ford-9, 3.50
This took months longer than planned, partly due to a serious delay by a perfomance shop. This started off with just a power steering cooler and then I decided to add a remote reservoir for it as well.
Since I added the resoervoir half way through the project, I didn't do enough research on it. I had a reservoir with the inlet and outlet on the bottom and I didn't think of the problem until everything was in place! The return line to the pump had too much of an incline and I thought the pump might starve. I searched more and found a reservoir from PSC Motorsports that had the outlet on the side. I called them to discuss my problems and they mentioned getting my PS pump output modified, especially since I have Hydraboost brakes. I had a month to finish the project and he told me it would be a 2 day turn around, so I sent it in.
2-3 weeks went by and I still didn't have the part, so I called them. I had asked them to install a -10 AN fitting on the inlet side of the pump and they were having some problems getting it too fit; they also waited about a week before they even started on it (2 day turn around?). I waited until the first week of May and I called again, they said the part was almost finished and it would ship the next day. 2 weeks later I still did not have the part, they didn't ship it until May 20th! During all this they never kept me informed, even though I stressed I had a short timeline. This is the worst service I've had from a shop, so be warned if you try using these guys.
Anyway, here are some pics. It's a -6 line to and from the cooler and a -10 from the reservoir to the pump.
The battery tray was cut away and I built a mounting plate to hold the reservoir. The return line as pretty level now.
Here's the 18 inch Derale heat sink cooler, just under the front bumper.
I also cleaned and painted the underside of the car. I'm glad I did it because I found some surface rust under the road grime.
I removed "GTO" from the fuel rail covers and bought some stainless steel "Firebird" emblems off ebay. I also painted them silver and dark grey. I like it!
Finally, on my Formula hood I removed the flat plate on the bulge and replaced it with aluminum mesh, this is the same mesh I used on the dash speakers. There's also a shield behind it to keep too much water from getting on the engine.
That's it! next winter I'll replace the other fluid reservoirs with a matching aluminum pair, so it's slowly looking better
Old May 31, 2008 | 12:10 PM
83MonteSS's Avatar
Re: winter projects FINALLY done!
Man that really looks great. Almost looks factory. Great work!!
Old May 31, 2008 | 08:15 PM
A10Beav's Avatar
Engine: LS2
Old Jun 2, 2008 | 09:24 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Thats damn fine man! nice work!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Formula8r89
Sep 22, 2015 04:24 PM
ericjon262
Sep 11, 2015 06:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
