Need Help, Wanting to light this car on fire :-(
Old Jun 10, 2008 | 07:37 PM
Bakernator's Avatar
I have been working on my LT1 swap for over a year (intermittently) and just dug it out of storage recently. I had a little trouble starting it up but finally got it going and brought it over to the garage to clean the dust off it. When I tried to start it about 2hrs later it wouldn't catch and run. I attempted a couple times and nothing. I let the car sit overnight and tried it the next day and it fired up and ran. I shut it off after it was running, and it wouldn't start up again. I tried it the next day and it fired up, but was not runinng on all cylinders at first, but then it came around and started running on all cylinders. I tried starting the car up the other day and now it won't run. Anyone have any ideas on it?
Old Jun 10, 2008 | 08:29 PM
6.LIROC-Z's Avatar
Engine: 6.0L LSX Carbed
Axle/Gears: 3.73 Strange 12 bolt
Re: Need Help, Wanting to light this car on fire :-(
Check the spark plugs, sounds like they may be fouled
Old Jun 10, 2008 | 11:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What did you do to clean off the dust?
Old Jun 11, 2008 | 03:41 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Check the basics... Fuel, spark. compression.
Old Jun 12, 2008 | 12:58 PM
bingo's Avatar
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
I am voting for fuel. How old is the gas? Are all the injectors spraying? What is the fuel pressure?
Old Jun 12, 2008 | 01:05 PM
Saleen85's Avatar
Could be a bad optispark.
midge54
Dec 27, 2019 04:14 PM
justin57
Aug 20, 2015 07:05 PM
MY87LT
Aug 17, 2015 08:43 AM
Omega
Aug 10, 2015 12:46 PM
djmarch
Aug 9, 2015 05:27 PM
