LQ4 Swap Header Question
Old Jul 11, 2008 | 02:59 PM
SovereignDragon's Avatar
Car: 1990 Trans Am
Engine: 305 TPI (for now)
Transmission: 700-R4 (for now)
Axle/Gears: 2.73 10 bolt (for now)
Alright, I'm building an LQ4 based 408 topped with Trick Flow 235 heads. What all header options do I have for this swap? I'm trying to get my parts list together so I can order everything together rather than picking up pieces here and there.
Old Jul 14, 2008 | 09:35 AM
87tpi350,6spd's Avatar
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Re: LQ4 Swap Header Question
Only one if you want to bolt it right up the hawks set up. you should read the sticky. However it looks like a couple of people are trying to modify sets that are for regular small blocks. So if you have the tools and skill you can do that also. I will probably be trying this method as I would like a larger primary size for my build. But by the time I gat to it there might be more options.
1984HO
Mar 19, 2021 11:59 AM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
