LT1 Oil filter mount vs L98. Anyone know?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Guys,
Need help from an LT1 swap pro. I need to use an LT1 oil filter adapter on my SBC motor due to needing to use a metric filter (long story, trust me).
Are the mount PADS as cast in and tapped on the blocks the same? Can I just remove my oil filter adapter, and screw on the LT1 adapter ?
I'm a little worried. I have a back up plan if this does not work, but I'd really like to be able to just use the LT1 part.
I imagine some of you guys unbolted the LT1 mount and put a SBC mount so you can run a fram PH5 or big filter or whatever, but I couldn't find any definitive answers while searching.
Thanks!
-- Joe
Thanks!
-- Joe
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: LT1 Oil filter mount vs L98. Anyone know?
I'm using a big filter on my LT1 and it still has the LT1 adapter, there isn't any special filter for an LT1 vs a regular SBC
The LT1 is a PF454, but I'm using the longer filter on mine, don't remember the part number but it is longer.
I went on Autozone just to check the part numbers for the adapter, the Melling part number for the LT1 is MFA350
The part number for an L98 is MFA350
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Thanks though.
edit: jason at vette2vette screwed one on a L98 block for me, so Looks like I'll be good to go.
Here is why I need it for the curious.
-- Joe
Car: 1990 Formula
Engine: 95 LT1
Axle/Gears: Weak 7.5 with 4.10s
Would that be the same adapter used on Z71s to clear the front driveshaft? If so, it should bolt right on. The 88-98(?) Chevy trucks used traditional smallblocks.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
In fact, I've owned 6 chevy trucks in my life. What absolute pieces of crap. I've owned 'em as old as a '84, and as new as a '98. All junk. I'm a dodge man now.
-- Joe
Car: 1990 Formula
Engine: 95 LT1
The last one I worked on was a 95 and it had the same type adapter you posted. It used a PF52 filter. Glad you figured it out.
maroe624
Apr 16, 2017 08:29 AM
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 21, 2015 09:32 AM
