LS1
LS1
Had a qusetion to throw out there. I have an idea of what I'm going to do, but I always like to hear other opinions. I have a LS1(364cc) out of Chevy Pick-Up. I've stripped it down to the block. I'm debating rebuilding the engine and putting in a '84 Camaro that's currently running a 350. Does anyone have any recommendations for a cam, heads, and intake for this block? And ofcourse I plan on making it carburated.
Car: 1991 Camaro Z28
Engine: 305 LB9 5.0L
Axle/Gears: POSI 2.73
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: LS1
what you have is a LQ4 A 6.0 iron block truck engine...its in the same family as the ls engines with interchangeable parts, but its not an ls1. thats like saying i have an l98 when u have an lg4 or somethin....just being technical....but back the the question at hand what is ur hp goal and what way will u be using the car,,,street strip, drag, autoxxx?
Transmission: 4L80E/4L80E
Welcome to thirdgen.org.
We have a forum for engine swap topics, and a sub-forum there for LSx topics (the LQ4 is in the LS family of engines). Moving this there.
Car: Camaro
Engine: 6.2L
Re: LS1
Second the L92 heads they cant be beat even CLOSE to beat for the money. Intake I'd go with the Edelbrock super Victor with a 950 demon and as big A cam as your teeth can handle with all the complimenting bolt ons and you should run low tens and ironically you'll probably still get decent mileage out of it.
First things first start by reading this;
https://www.thirdgen.org/forums/ltx-...want-swap.html
Welcome to TGO!
Welcome to TGO!
