alt and gauge not working
Old Sep 5, 2008 | 06:38 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
So I put an LT1 in my 89 bird and I keep burning up alternators. The tack only works when the turn signal or brake are on. I know there should be a resistor on the red wire that goes to the alternator, what size should it be and where can I find one?
Thanks for the help
Old Sep 6, 2008 | 03:01 PM
CamaroKid89RS's Avatar
Car: 89 Camaro RS/SS
Axle/Gears: 10 bolt with 3.42
Re: alt and gauge not working
I couldn't get that method to work with my alternator when I did my LT1 swap and kept burning up alternators too. What did finally work was I connected a 12V when ign is on to the F terminal of the alternator. That should fix your problem as it did with mine.
Old Sep 7, 2008 | 01:39 PM
Engine: 5.8
I have it on the L terminal on a 12v switched now, where did you get a connector that goes to the F terminal? Does it stay a one wire or go to a two?
Old Sep 8, 2008 | 05:11 PM
It's still a 1 wire, you just connect it to a different terminal on the plug. Look at the plug and it should have more than one terminal on it; just switch it to F. F = field. L = light, that would mean that if you connect it to F you're energizing the field, and L would be if you wanted a little light to come on (dummy light situation) if the alternator failed.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
