LT1 VATS bypass
Old Oct 22, 2008 | 02:37 PM
86LT1's Avatar
Car: 1986 Camaro IROC-Z
Engine: 357 LTx
Transmission: T-56 6spd
Axle/Gears: GM 7.5 10 bolt with 4.10 richmonds
LT1 VATS bypass
Well first off I wasnt sure whether i should have put this ? in here or under the LT1 forum, but anywase I put it in both haha.... My ? deals with the VATS bypass on the LT1 ECU. It turns out when I sent out my compter to be burnt for the specifications of my engine they forgot to burn out the vats so now I'm stuck with a vehicle that will run for only 4 seconds and I was wondering if anyone would know which wires/pinouts on the connectors to the computer are the ones for the vats??? My plan was to locate those wires and splice resisters where neccessary. My other question was I heard of a piece you can purchase that plugs between the ECU connector and the ECU itself that is a VATS bypass module? has anyone else heard of this... I'm going to call summit/jegs and ask about it but I was just wondering if anyone knew of it or used it.
Thanks for the help
Old Oct 22, 2008 | 04:31 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Re: LT1 VATS bypass
Mabey this will help ?
http://shbox.com/1/vats_bypass.jpg
Or someone will chime in with a better way out.
Old Jan 2, 2009 | 03:55 AM
bucknastycamaro's Avatar
Car: 1991 camaro rs
Engine: current tbi305 swapping to 94 lt1
Re: LT1 VATS bypass
ok i bought a vats bypass off of ebay and i=ts a three wire hook up for a 94 lt1 were would it go?
$750 L98
Feb 1, 2025 02:25 PM
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
sahlomonic
Sep 20, 2015 07:15 PM
Racerx974
Sep 19, 2015 10:16 AM
