lt1 cam selection help please
Old Nov 10, 2008 | 11:41 AM
bmfIROC-Z's Avatar
im going to be putting a fresh rebuild on my lt1 this winter and i want to put a better cam in and i was just wondering what would be the best choice with stock heads and converter?,i dont want anything to radical for now ,also what other mods should i throw at it to compliment the new cam while im at it?thanks in advance,joe
Old Nov 10, 2008 | 03:12 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: lt1 cam selection help please
Look at Comp cams XFI series cams, they're made for the LT1s and can get from mild to wild in that line.
Old Nov 10, 2008 | 04:10 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
If you want to keep the stock converter I'm going to say the hot cam.
http://www.ls1tech.com/forums/lt1-lt...wap-guide.html
Old Nov 10, 2008 | 08:23 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
I do not care what people say about the LT4 hot cam!!!! I am running 10s with one in a car that still has stock heads and inspection stickers on it. The trick is do your homework first and match every part from the front to the rear of the car.
Old Nov 11, 2008 | 03:16 PM
bmfIROC-Z's Avatar
should i use the stock rocker arms ,1.5rr's or 1.6rr's with the lt4 hot cam and stock heads?if i get rr's will i have to have the rocker arm studs pulled and the stud holes tapped for guide plates?and will the stock valve springs be ok to use?,thanks in advance,joe
Old Nov 11, 2008 | 03:39 PM
Car: 1992 camaro
Axle/Gears: 3:73
http://store.summitracing.com/egnsea...09536&D=309536
That kit will get you every thing you will need. Some say the springs are junk because they are made to work with the LT4 valves witch are lighter valves.
Unless you go NSA rockers you should not have to use gideplates or harden pushrods. I would go with 1.6 rr on any cam.
Old Nov 11, 2008 | 04:38 PM
bmfIROC-Z's Avatar
will i need a bigger tb with the lt4 hot cam or is the stock 48 mm sufficient?and im also getting a set of nitto drag radials ,will i need sub frame connectors?
Old Nov 11, 2008 | 05:12 PM
Car: 1992 camaro
Axle/Gears: 3:73
A 48 mm will work and support upwards of 400hp. And the SFC never hurt if you have the cash get them.
Old Nov 11, 2008 | 07:08 PM
bmfIROC-Z's Avatar
will i need bigger injectors?
Old Nov 11, 2008 | 09:54 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
Check out this link and the cam at the top http://www.elliottsportworks.com/lt1.html I run his LE2 cam with his ported heads and it does well.. he can provide cam only, all the parts you need, and some very good free advice..
For your power level a stock TB, stock injectors, and a mail order tune will work just fine.
Old Nov 11, 2008 | 11:24 PM
bmfIROC-Z's Avatar
so the stock injectors and tb will work ok with the hot cam?cause' i read somewhere that the lt4 came stock with 28lb/hr injectors and my stock injectors are only 24lb/hr,what about the stock valve springs?will those be ok with the hot cam to?
Old Nov 12, 2008 | 01:42 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
just get the kit from summit mentioned above, if you don't choose Lloyd Elliot. it has springs and lifters already.
does anyone know if they are 1.5 or 1.6 RR's?
Old Nov 12, 2008 | 04:21 PM
Car: 1992 camaro
Axle/Gears: 3:73
If refering to the HC its 1.6rr, and yea now Lloyd offers some cams that will work with the stock convertor.
Old Nov 12, 2008 | 04:26 PM
bmfIROC-Z's Avatar
i only got about $2000 to play with and i have to get all the parts for a complete rebuild, drag radials and whatever else that i might need to support the cam upgrade + machine work + a tune, so i dont really wanna pay $600 for the lt4 hot cam kit cause i can buy just the cam for $210 and buy the NEEDED accessories seperatly for cheaper,so what is absolutely needed for the lt4 cam to work properly in my car?thanks,joe
Old Nov 12, 2008 | 05:52 PM
Car: 1992 camaro
Axle/Gears: 3:73
The NEEDED accessories for the hot cam is CAM,SPRINGS you dont have to have the 1.6 rr but with the 1.5rr you will lose lift. If you do not mind used parts it can be done better and cheaper.
Old Nov 12, 2008 | 07:16 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
The stock injectors should work for your power level you can look here http://www.iroczone.com/calcs/injectorsize.htm and calculate it out.. it doesn't hurt to go bigger but you will be able to get away with 24lbers for a while but you will need a program and a higher duty cycle to provide the fuel.
You could always email any of the mail order programmers around and see what they recommend.
Old Nov 12, 2008 | 09:36 PM
bmfIROC-Z's Avatar
cool ,thanks for all the help guys
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
