Which valve cover gasket?
Old Nov 22, 2008 | 12:49 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
What valve cover gaskets are you guys using which the Canton Aluminum valve covers? I ordered a pair and need to order gaskets now... I think I have new factory style gaskets but not sure if that will work?
What else do you guys do to get a good seal? Set in RTV or anything?
Old Jan 4, 2009 | 07:54 PM
Car: 1992 z28
Re: Which valve cover gasket?
Anyone?
Old Jan 4, 2009 | 08:38 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Just order some quality fel-pro blue rubber ones with the steel shim inside and they'll last a long time.
Old Jan 4, 2009 | 08:45 PM
Car: 1992 z28
ok thats what I have. Just wanted to double check.
db057
Sep 4, 2015 07:57 AM
Victor6
Aug 30, 2015 02:09 AM
g.l.mos
Aug 22, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 8, 2015 01:18 AM
