Mystery fuel rail fitting
Old Dec 7, 2008 | 09:52 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
This was on the rail when I got it. I have no idea what type of fitting this is. I need to convert it to -6AN. Any ideas?
Old Dec 7, 2008 | 12:07 PM
TexasLT1's Avatar
Car: '92 RS
Re: Mystery fuel rail fitting
Yeah, cut it off and weld on a -6AN or get the fuel line with the opposite connector on it.
Old Dec 7, 2008 | 12:37 PM
Omega's Avatar
Engine: LS1 / LS3
I would like to go the opposite connector route
Old Dec 7, 2008 | 09:12 PM
TexasLT1's Avatar
Car: '92 RS
Looks like the fuel rails from a truck engine? You should be able to get the fuel line from one of the trucks and use that.
Old Dec 7, 2008 | 09:46 PM
82CAMAROBBC's Avatar
Car: 1982 Camaro
Engine: 454
Transmission: TH350
Axle/Gears: 410
It looks like a compression fitting (union) you can get from the hardware store. Is it brass?
Old Dec 8, 2008 | 02:30 PM
TexasLT1's Avatar
Car: '92 RS
I didn't get a chance to post again but after I thought about it again, that was my conclusion as well. Looks like a standard compression fitting.
Old Dec 8, 2008 | 03:12 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
How about another shot? from the side perhaps? Move the nut back and forth and get a couple shots of what all is going on there.... Does it look factory or like someone stuck it on?
Old Dec 21, 2008 | 04:32 PM
Omega's Avatar
Engine: LS1 / LS3
Just in case someone runs across this fitting too, it's called a swagelok.
Unfortunitly I can't find a male to AN adaptor.
Old Dec 22, 2008 | 02:26 PM
cam-'s Avatar
Car: Camaro
Engine: 6.2L
Looks like a compression fitting to me. Swagelok is a brand of compression fittings that are very high quality ( its all I used in my swap for fuel lines ). The main difference between the swageloks and regular compression fittings is the material ( swage uses high quality strong alloy stuff i used their stainless line ) and the swagelocs use two ferules that are tapered and lock together rather than the brass round ball thing that most use.
Anyways regardless all you need to make that fit is a compression fitting female to whatever size NPT you want to use. From there you can adapt to anything you want with a small coupler and another NPT to whatever
Hope that makes sense
http://www.swagelok.com/search/find_...0000007/type-1
Old Dec 22, 2008 | 06:55 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Yes, It's a Swagelok fitting. The question is do you have the room needed to adapt to the other connection, and is the other connection on a flex hose, or tubing?
I don't think Swagelok has adapters for automotive fuel lines and as mentioned it may take a minimum of 2 adapters and that can take up a lot of room.
If there's enough tube behind that connector I'd cut it off and use something like Russell Performance tube and hose fittings.
Old Dec 22, 2008 | 09:20 PM
Omega's Avatar
Engine: LS1 / LS3
Fortunately I have a lot of room to go from the rail to the pushlok hose I plan on using for fuel line. However, I do not want 4 inches of different connectors.
I found this: http://www.swagelok.com/search/produ...art=SS-PB6-SL6
Which I hope will enable me to go directly from the fuel rail fitting to the fuel hose. My main issue at the moment is that these fittings are not easily obtained unless you are a business.
If that fails, I might have to go with a new rail. There isn't much left and I'm not sure if the swagelok destroys the tube when you put it on. Is this the case?
Old Dec 22, 2008 | 09:54 PM
82z28man's Avatar
Car: 91 Z28
Engine: 6.0 LSX Single turbo
Transmission: 4l80E
Axle/Gears: Moser 9" 3.55
I have some rails for sale if you need them. I'd like $40 for them shipped.
Old Dec 22, 2008 | 09:59 PM
Omega's Avatar
Engine: LS1 / LS3
Thanks, but I'm not sure that truck rails will work with my setup... will they?
Old Dec 22, 2008 | 10:21 PM
82z28man's Avatar
Car: 91 Z28
Transmission: 4l80E
No i dont think so, these are off a truck manifold, i thought thats what you were using.
Old Dec 23, 2008 | 03:58 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Omega, If you can't get a local business to buy it for you let me know and I'll buy one from one of our suppliers and ship it to you. I'm in Houston, Texas.
Russell also has quick release fittings And LS1, LT1, and LT4.
http://www.russellperformance.com/mc...rel/main.shtml
http://www.russellperformance.com/mc...fit/fuel.shtml
Frozer!!!
Jan 19, 2024 04:55 PM
Andrew6.688
Dec 13, 2015 10:59 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
