5.3 truck engine in 85 trans am
Old Dec 21, 2008 | 10:06 PM
T TA 355's Avatar
I thought you could use all of the acc. from a truck engine except the oil pan. I guess I'm wrong? I have been searching I thought someone had done it. chop the hood.
Old Dec 21, 2008 | 10:10 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: 5.3 truck engine in 85 trans am
no the alternator is too tall. So either buy relocation brackets or a complete fbody setup
Old Dec 22, 2008 | 08:20 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
You can use all of the truck stuff if you really want to.
Pan will hang too low though and your probably going to tear the bottom off it on your first drive.
As for acc, the alternator sits high and would require a wide cowl hood (jongbloed or something i think covers) and you can use the truck intake also if you go this route.
Speartech's thirdgen uses truck acc.
Old Dec 23, 2008 | 07:44 PM
T TA 355's Avatar
They have a 2001 ls1 from a TA with a crank underdrive pulley.
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Exxon Limited
Aug 9, 2015 08:13 PM
