Lsx camshaft
Old Dec 27, 2008 | 10:59 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Lsx camshaft
i am currently putting together a 5.3 liter ls engine im my 86 camaro and would like to know anyones personal oppinion for a camshaft for my setup. i will be running the stock shortblock with some type of camshaft and an aluminum intake, tci super street fighter stall and ab 7-10 pounds of boost. i was looking at the lingenfelter GT2-3 camshaft but im not sure this is what i need. Any info would be greatly appreciated!!
Old Dec 28, 2008 | 12:07 PM
macdadyZ28's Avatar
Car: 87 Formula
Engine: '00 LM7
Transmission: 4L60e
Axle/Gears: 3.23 posi
Re: Lsx camshaft
GT2-3 is a favorite of the turbo / nitrous guys for 346 displacement. The motor I bought for my ls1 swap had it installed already. Its all here-say, but he said the motor absolutely screamed on spray with that cam. not sure what that equates to for turbo and 5.3 though
Old Dec 28, 2008 | 12:21 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: Lsx camshaft
the cam will act like it has 6* more duration ing a 5.3L application.
ex. TR224 cam in a 5.3 would act like it was a 230/230
Your best bet would to be look for somethin a little smaller
Old Dec 28, 2008 | 05:24 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Re: Lsx camshaft
So what would be my best choice? i know the duration should be around or under 220. but im not the best camshaft person.
Old Dec 28, 2008 | 06:05 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Re: Lsx camshaft
i think im going to just call xXx and get john to make me a camshaft....
Old Dec 28, 2008 | 08:32 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Re: Lsx camshaft
Not sure what your looking at if your going boosted, your looking 214-216 area for duration, and you want min 116LSA so you can build boost if your planning on turbo'ing the car
Old Dec 28, 2008 | 08:44 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Re: Lsx camshaft
i think i would come out better just emailing comp. and Flowtec Induction and ask them what they think....
Old Dec 29, 2008 | 03:33 AM
1bdbrd's Avatar
Car: 1991 Trans Am
Re: Lsx camshaft
You don't HAVE to have 116LSA or higher to build boost. There was a guy on ls1tech a couple years ago that ran a custom grind cam with a 112LSA to test out his theory on cleaning the combustion with the extra air from the valve overlap.
I think it worked pretty well. He put down around 500-550whp with a cam, bolt on and p1sc procharged ls1 at around 5lbs I believe.
I don't see the problem running the GT2-3 in a 5.3 really. It might move your powerband up some but its not going to make the car hard to drive by any means.
Old Jan 3, 2009 | 08:06 AM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Re: Lsx camshaft
I have a LPE GT2-3 cam sitting on the shelf, I'm not going to use. PM'd me interested in it.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
GTAman
Sep 26, 2015 02:01 PM
Buggy Disaster
Sep 22, 2015 01:15 PM
