caught on a few snags..help!
Old Jan 11, 2009 | 12:19 AM
whiteghost92's Avatar
my dad and i are swapping an ls2, t-56 into his 92 z28 and i have a couple questions concerning the swap..
-How do you guys set up your clutch master cyl? we've measured and measured on the firewall, but have yet to cut a hole for the clutch because we can't seem to find a way to keep the pushrod straight. The bracket on the master cyl is at an angle, would we have to fab up a spacer? (transmission and clutch cyl are from a 02 trans am).
-Where is a good place to route the wiring harness for the new motor? From there, where should the new computer be mounted? My dad said that we're keeping the original computer and just adding the new one for the LS2...
Thanks guys! I apologize if some of the information is reallyyyy easy to find, but I did a quick search and didn't come up with what i was looking for.
Old Jan 11, 2009 | 07:30 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
Re: caught on a few snags..help!
right under the carpet lining you should find 3 diples on there..cut a hole.. and the holes for the bolts.. thats exactly what i did. mine was automatic in the past..
my clutch set up is pretty good so far.
Old Jan 11, 2009 | 07:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
I used the clutch pedal bracket as the template. My '82 didn't have hydraulic clutch (besides being an automatic car, '82 used a cable clutch), so there wasn't anything close.
https://www.thirdgen.org/forums/ltx-...tml?highlight=
(Not sure if the link is working. Try an advanced search on this sub-forum for "t56 pedals" and threads started by me.)
Old Jan 11, 2009 | 08:27 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
no point in keeping the old computer it doesn't do anything anymore.
I put the LS1 PCM right where the old ECM used to be.
Cornholio7979
Sep 20, 2018 02:31 AM
chazman
Aug 28, 2018 03:25 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
fasteddi
Sep 10, 2015 09:32 AM
chazman
Aug 22, 2015 02:01 PM
